Engine start problems Post issues with engine start here. Does not start, does not run, etc.
cold start is fine, it’s when I turn the car off is the problem
Old Jan 11, 2020
slvgga's Avatar
slvgga is an unknown quantity at this point
So the cold start is perfectly fine but if I go put gas to where I have to turn off the car, it won’t start again for another hour or two. Why is this? I was told it might be my fuel pressure regulator?? On that note I don’t even know where the fuel pressure is located??
Old Jan 11, 2020
Colin42's Avatar
Re: cold start is fine, it’s when I turn the car off is the problem
What does it do when you try to start it?
Old Jan 11, 2020
slvgga's Avatar
it starts up perfectly fine, no noises or anything on cold start.
2nd start, it starts with crank, I know it’s not the battery or alternator because I just replaced them.
Old Jan 11, 2020
Colin42's Avatar
So it just cranks longer?
Old Jan 11, 2020
slvgga's Avatar
yea
like it wants to start but something holds it back
Old Jan 11, 2020
Wankenstein's Avatar
A little confused by your wording in this. Are you saying this happens only when you stop at a gas station, fill the tank and try to start the engine again?
Or are you saying this happens every time after car reaches operating temp?
I had a 2007 Mazda 3 that would not start well only after filling the tank with gas and it turn out to be caused by the purge solenoid valve (common issue with this Mazda 3 generation): https://www.mazda3forums.com/122-sto...s-fill-up.html I do not know if the purge valve has ever been an issue for Civic engines.
Old Jan 12, 2020
slvgga's Avatar
well just anywhere, like if I made a quick run to the store and came back out and tried to leave it wouldn’t turn back on for like an hour or two..
Old Jan 12, 2020
Colin42's Avatar
Got a scanner with live data? One of the temp sensors may be giving a false reading
Old Jan 12, 2020
Going back to the initial prognosis of fuel related... IIRC, the FPR is integrated into the pump on a 7thgen. I never had that problem, so to the google machine I ran. Lots of sources state fuel issues, so the FPR wouldn't be a bad place to start. Could be fouled injectors, too. My ex's godfather (taught at University Technical Institute -- That auto school you see commercials for when watching car shows), and he swears by B12 fuel system cleaner. At $6 a bottle, wouldn't be a bad experiment. I tried a few bottles of it in my 2002. Got better fuel economy after a couple treatments with no changes in fuel type/driving style. I'll keep looking into the issue tho
Old Jan 12, 2020
slvgga's Avatar
wow really? I’ve seen that the FPR is integrated into the fuel pump but never found a solid answer. But I’ll definitely look into buying those bottles.. sounds like you had some success with it
Old Jul 20, 2020
sinkenken's Avatar
sinkenken is an unknown quantity at this point
Mine was doing same. In the end it was an intermittent TDC sensor which was faulty sometimes after stop and heat soaked or on really hot days.
Replaced with new Honda sensor which was a different p/n and no problems since.
Sethster99
Apr 6, 2013 12:51 PM
Alex_1994civic
Jan 27, 2013 01:55 AM
Asblasor
Aug 23, 2012 03:40 PM
gearbox
30
Apr 3, 2005 07:14 PM
03CivicEX03
Nov 14, 2004 01:41 AM
