Engine start problems Post issues with engine start here. Does not start, does not run, etc.
no crank, no start, no horn.
Old Sep 15, 2022
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
Hi everyone I'm Trace. I have me a 2002 civic D17A2 manual. Yesterday morning I woke up and was introduced with this issue where I have no horn, no click, no crank no at all coming from my car.
Check battery it shows 12.5v battery is new anyway. Check ever fuse in engine bay. The black once supposed to be relays, I pulled them and shake them but no sound. Look at the others that has clear top on them and they are no signs of chop on the wirings..
Pull the important fuses inside the car under the steering but no signs of chop fuses either.
What could be my issue here? I used to hear clicks coming from those relays underneath the glove box no there's no sound anywhere. I appreciate someones help here because this is my only transportation around.
Old Sep 15, 2022
BrotatoChip's Avatar
Super Moderator
Re: no crank, no start, no horn.
Just looking at the fuse does not mean it is good. Use a meter to check for battery voltage on both sides using the little probe spot.
Old Sep 15, 2022
I just tested the fuses with multiple meter and relay with Alligator clip wire connect to the battery and they clicks so that tells me that they are Fine.
What else can you suggest to me.?
Old Sep 15, 2022
Colin42's Avatar
Check battery connections, clock spring, ignition switch.
Old Sep 15, 2022
It couldn't be ignition switch. There no light in the dash. The key doesn't make any sound. The green key light doesn't show up in the dash.
​​​​​​IT couldn't be any of the above you mentioned.
the battery test read 12.5V so it's good.
I check fuses, relay and everything read. Not sure what to think next.
Old Sep 16, 2022
Super Moderator
It could absolutely be the ignition switch. Not the immobilizer but the actual ignition.
You still need to actually measure battery voltage at the fuse. For instance, if you physically look at fuse 2 in the under hood box it could check out just fine. But, electrically it comes after fuse 19 (the big 80A). So, the 80A could be blown.
12.5V does not guarantee the battery is good. A load test would confirm the battery is good. You can somewhat mimic this by measuring battery voltage while attempting to start.
Does anything turn on at all? Dome lights when a door is opened? Headlights? Hazards?
Old Sep 16, 2022
Colin42's Avatar
This.
Learn to do electrical diag properly
Free_Fall
Apr 27, 2022 07:35 AM
Keylargo
Sep 12, 2021 06:17 PM
guru1214
General
Oct 18, 2019 09:34 PM
kasualkiller
Sep 25, 2014 07:53 AM
pnoyster2k1cvic
Nov 14, 2004 03:47 AM
