H O R N -- P R O B L E M -- H E L P !!!
Old Nov 10, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
Arrow H O R N -- P R O B L E M -- H E L P !!!
thanks you guys for checkin out this thread... I need help bad! I got a tripple air horn installed about 3 months ago, and it was workin great until, a couple days ago that when I pressed it for about 5 seconds it just stopped working...
i check fuse, connection, ground etc... and everything looks good, I cut the wire that goes from the steering wheel horn to the pos for the horn motor and I connected it straight to the battery + and it works... but when I connect it back to how it was, it doesn't wanna work watafak!
i change the fuse from the fuse box for horn, and that didn't work either, and I just wasted 7dollars from the fukin dealership, for no return no fukin exchange for electronic **** even if you just connected it for less than 20 secs...
anyway... you guys have any suggestions on how to get this thing workin... it's really tough with out a horn... thanks again guys I really appreciate it!
Old Nov 10, 2004
DragonAce's Avatar
DragonAce is an unknown quantity at this point
is it running thru a relay??
Old Nov 10, 2004
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
the stock horn is controlled by a relay in the fuse box in the engine bay since the contacts on the steering wheel cant handle the power required to activate the horn. you should hear a clicking sound coming from the fuse box when you press the horn. If not, thats your problem
Old Nov 10, 2004
CelCUs's Avatar
CelCUs is an unknown quantity at this point
If you know it works, then just get a fuse holder and run a new power to the battery
Old Nov 10, 2004
armieo's Avatar
< My future wife.
Relay baby.
Old Nov 11, 2004
Balut Eating Champ
yes it is running through a relay, it was working for about 3 months then it just stop all of a suden...
Old Nov 11, 2004
DragonAce's Avatar
so horn button (steering wheel) to horn (you're using the original wire)/horn to relay/relay to power right??
sounds like the relay is probably pooched..
Old Nov 11, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Just replace the relay...they are like $3
Old Nov 11, 2004
HEBEGEBZ's Avatar
HEBEGEBZ is an unknown quantity at this point
I know nothing about this but I think I am having the same problem. Where is the relay and where do I get a new one.
Old Nov 11, 2004
Balut Eating Champ
the relay is in the fuse box... check it... and from the dealership for 7 bucks!
Old Nov 11, 2004
DragonAce's Avatar
not the oem one in the fuse panel (unless you're running the stock horn)..
but the one that probably came (should have anyway) with your after-market horn..
it did come with one right??
those after market horns usually suck up a lot more juice than the stock system can handle
i got the dual Framm horns and although it runs from the stock switch it comes with a relay that takes it's power straight from the battery
Old Nov 14, 2004
Balut Eating Champ
the thing is, I got the power + straight from the wheel horn... coz for some reason if i connect the power to the battery and the wheel horn for act switch it won't work... like i said above it was workin for a while and it just stop all of a sudden... did I fry some ****?
