cranks no start O2 sensor voltage high [solved?]
My '02 Civic suddenly wouldn't start the other morning. It cranks strong. I have spark on all four cylinders. I can hear the fuel pump and smell fuel after trying to start, so I believe it is getting fuel. All pass from the computer. Sensor outputs all look reasonable except for the O2 sensors that are both reading 1.275 volts, even with both sensors unplugged. Is this 1.275 V reading the normal pre-start state for these O2 sensors, or does indicate something to look further into?
re: cranks no start O2 sensor voltage high [solved?]
o2 issue shouldn't prevent it from starting unless possibly a clogged catalytic converter. Could be a flooded fuel situation? Try starting it with gas pedal fully depressed as that will disable the fuel injectors and allow maximum air into the cylinders.
If that doesn't work try starter spray or TB cleaner in the throttle body while starting.
How did you determine it's getting spark on all cylinders?
I tested spark with my spark tester. Remove each coil from each plug one at a time, connect to spark tester, ground spark tester, turn engine over and observe spark in tester. It jumps the 30k Volt gap, so the spark is there and is as strong as it ought to be.
Will try some starter fluid.
Well, now I am confused. I sprayed a good amount of starter fluid into the intake and it started. I let it idle, figuring it would burn up the starter fluid and then stall, but it kept idling for a good 5 to 10 minutes, while I rounded up my scanner, hooked it up, and played around. O2 sensors were still unplugged, so I got O2 heater ckt codes, and the O2 sensors were still reading 1.3 V. Plugged the O2 sensors back in and the O2 sensor voltages dropped to 0. At this point, it is idling smooth, as if it was completely unaware of its stubbornness of the last week or so.
After idling several minutes, I shut it off, then immediately restarted it. It started easily.
So, now, I guess I wait a while and try starting it again later and see if it starts or not.
One way or another, I am confused. I generally don't believe cars fix themselves, but....
Intermittent electrical issues are the hardest to diagnose. Checked batt voltage with the engine running and off?
If it starts and runs normally in the coming days you can likely chalk it up to fuel flooded cylinders. Did you ever try starting it with the gas pedal fully depressed as I mentioned a few replies ago?
So far, it is starting and running fine. I guess we'll chalk it up to flooded cylinders. I did not try starting with the pedal to the floor, but I also would have expected too much gas in the cylinders to dissipate over a day or too rather than a week or two.
Thanks to all for the interest and the help.
Could be a possibility of worn fuel injector O-ring(s) causing a leak into the cylinder(s). However, unless the issue comes back soon that may not be a concern. Here's a read https://www.injectorrx.com/fuel-inje...uel-injectors/
DaBoss1325
Electrical
Apr 30, 2022 11:48 AM
Levi likes si
Jul 13, 2013 08:29 AM
Levi likes si
Jun 23, 2013 09:26 PM
