Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Car wont start
Old Dec 31, 2018
CD_Hokie's Avatar
CD_Hokie is an unknown quantity at this point
Car wont start
I have read through the very detailed articles already on the forum. I just wanted to see if any previous repairs could create this 'non-start' situation-
History- i just got my cat converter and cam shaft sensor replaced last month. Had to drive the car about 900 miles from place of repair back to my home town. Had an O2 sensor light come on and it went away on its own during this trip. No problems otherwise...
Present day- Had to fill up gas last night. As I went to crank up the engine to leave, the car would not start. Got the car jumped and got the battery and alternator readings from O'Rielly's and they said that the battery is fine and so is the alternator. They did however find that the negative terminal clamp was loose and came off easily. I got the car jumped again and drove the car around another 25 miles or so. When I tried to start the car again immediately, it didn't start. The cluster lights come on, the radio can be turned ON, the dome lights come ON, the front lights come ON as well.
I wanted to ask if there was a way I could check if the crank shaft sensor was installed correctly and if it could have caused something else to be loose, before I try to go through these links-
https://www.civicforums.com/forums/3...eshooting.html
https://www.civicforums.com/forums/1...ont-start.html
Thanks!
Last edited by CD_Hokie; Dec 31, 2018 at 10:43 AM. Reason: Wanted to add more information
Old Dec 31, 2018
Re: Car wont start
Does the engine not start because the starter does not operate? (No crank)
Old Jan 1, 2019
CD_Hokie's Avatar
Re: Car wont start
Sorry, I am not sure. When I try to turn the key from "0" position to "3" position, nothing happens.
This is very sudden as I didn't really get any indication. The dome light and the dash board lights up properly. Today 24 hours after posting my question, I can't seem to be able to unlock / lock the car using the remote.
Old Jan 1, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Car wont start
If the battery is good then when you hit position 3 you should hear either a rapid clicking sound, or, the starter sound (ermmm,ermm,ermm,ermm).
-If you hear the clicking sound, then there is a poor connection to the battery.
-If you hear the starter, then there is a fuel or ignition problem.
-if you hear nothing, then as ezone said, the starter is dead and needs to be replaced.
Old Jan 2, 2019
Re: Car wont start
This could also indicate a starter problem.....but actual testing should be done before wasting money replacing parts needlessly.
Got the car jumped
If it starts normally and consistently while connected to jumper cables and another car battery, the starter worked.
Focus on your battery and cables/terminal clamps/connections.
Old Jan 2, 2019
CD_Hokie's Avatar
Re: Car wont start
Okay. Thanks! I will start by taking the battery out and cleaning out the terminals. Will keep you posted. Thanks again!
Old Jan 2, 2019
Re: Car wont start
battery is completely dead?
Old Jan 2, 2019
CD_Hokie's Avatar
Re: Car wont start
There were no signs of dead battery or weak battery. Filled up gas, tried to start the car and Nothing!
Old Jan 2, 2019
Re: Car wont start
Au contraire. To wit:
Got the car jumped
Sounds like the FIRST thing I'd be checking is the battery.
They didn't load test the battery.
I kinda bet there's only about 10 people left under the age of 50 who actually know how to do such a test AND has the necessary equipment to do so.
The hand-held battery gizmotron most parts stores and shops use now only checks one of about 17 different ways a basic car battery can fail. It's main purpose as a sales tool is usually great, but that does not make it a 100% reliable battery tester.
Old Jan 3, 2019
BrotatoChip's Avatar
Super Moderator
Re: Car wont start
I recently troubleshot my sister-in-law's Toyota Yaris with a no start no crank issue. When you tried to crank it you'd hear a clicking noise. I immediately thought the battery was low so I checked the voltage but it read ~12V. After checking some other items and getting no where we decided to check battery voltage while trying to start and read ~4V. Replaced the battery and all was fine. The battery appeared to be ok until a load was placed on it.
ianator13
Dec 7, 2015 08:09 PM
01silverHonda
Jul 11, 2013 10:06 PM
kbook
Apr 8, 2011 11:35 PM
noxit.r3fk
Feb 24, 2007 12:56 AM
darklegacy540
Feb 12, 2004 03:38 PM
