Engine start problems Post issues with engine start here. Does not start, does not run, etc.
not starting when engine is cold
Old Nov 17, 2024
giorgi's Avatar
giorgi is an unknown quantity at this point
1.7l 2001 civic is not starting when the engine is cold. it has P0118 engine coolant temp sensor and P0141 O2 sensor code. i changed temp sensor 5 times but still the same issue. checked the battery and the fuses and everything is okay. what i discovered is, when i pour hot water near the temp sensor the car starts right away. can anyone help me?
Old Nov 18, 2024
Colin42's Avatar
Re: not starting when engine is cold
I'm guessing you're buying cheap aftermarket sensors.
buy an oe denso sensor. Get one from a junkyard if you don't want to buy new
Old Nov 18, 2024
giorgi's Avatar
i have tried oem sensors but still the same issue
Old Nov 18, 2024
GolNat's Avatar
Prelude Owner
Make sure the wires to the sensor are okay. Maybe the water is conducting an otherwise bad connection.
wizdomonwheels
Nov 18, 2023 08:47 PM
Dankers92
Jan 16, 2019 09:18 AM
pritz786
Jul 20, 2017 12:02 AM
leblanc
Oct 19, 2012 10:27 AM
Protan988
20
Jul 28, 2011 02:26 PM
