Engine start problems Post issues with engine start here. Does not start, does not run, etc.
2001 Honda civic ex start and stall Help
Old Aug 4, 2021
Hakced's Avatar
Hakced is an unknown quantity at this point
My 2001 Honda Civic starts and then stalls. It sounds great when it starts up stays running for a few seconds and it just bogs out. Giving a gas does nothing except make it stink like gas. I changed the EGR valve it did nothing I disconnected the exhaust right after the exhaust manifold thinking back pressure from a bad cat did nothing.
Old Aug 4, 2021
Re: 2001 Honda civic ex start and stall Help
you potentially have engine codes (CEL)
check them
engine needs air, spark and fuel, in the right timing, one of these are the cause
moved to engine start problem section, plenty of cases here, take a time to read around what others have had
Old Aug 5, 2021
BrotatoChip's Avatar
Super Moderator
My guess is fuel pump. Fuel pressure check would be a good place to start.
Old Aug 6, 2021
Hakced's Avatar
Here is where I'm at I disconnected the crankshaft sensor and the engine started. So I tore it down a little took the valve cover off move the power steering lines because they were right in the way. The brake booster is right in my way also but it's got to stay I don't feel like bleeding all the brake lines or breaking any. I can't see the timing marks on the engine for the crankshaft just the marks on the pulley itself so I'm going by when the Piston is all the way up on the compression stroke and cylinder one and it seems like the cam is not in the correct space. I really don't understand how it could jump a tooth or two because the belt seems tight. I would just replace the crank sensor but I don't want to just replace parts and really can't afford to. How can I be sure I'm at top dead center. Is just by eye with a screwdriver accurate enough?
Old Aug 6, 2021
Super Moderator
FYI that would be the ABS pump, not the brake booster.
No, it isn't. Take a look at the DIY below for checking engine timing. There are marks on the crank pulley as well as the lower timing belt cover that will tell you when piston 1 is at TDC. You very well may have a failing crank position sensor. Let us know your results before buying a replacement.
https://www.civicforums.com/forums/1...ne-timing.html
jdawgzcivic
Nov 15, 2013 04:24 PM
Jocey05
Oct 30, 2012 10:52 AM
BR549
Jul 16, 2012 03:10 PM
2008vistablue
Mar 4, 2012 07:40 AM
