PDA
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Engine swap component question
  2. P0302 code
  3. Engine Grind Car won't start
  4. Charging System Issue
  5. no start
  6. '02 EP3 High Compression - Rough Idle - Lousy Heat
  7. Lurching/jerking problem. Please help!
  8. issues starting after TDC replacement
  9. Noisy valves for a few seconds on cold starts (usually)
  10. 04 civic AT can shift but will not engage
  11. 02 civic lx weird noise from power steering pump or bearings
  12. supercharger boost sensor code p0238 circuit a
  13. Radiator replacement and hood release cable
  14. Whats the most likely source of this annoying buzz/rattle coming from the rear deck?
  15. Air Compressor Reroute
  16. AC Clutch stuck like mud
  17. head bolt torque
  18. Does this sound like a tranny problem?
  19. VIN check Anyone?
  20. 2005 Civic LX Manual Transmission ECU failure
  21. '02 lx 1.7l Shuts down when driving on freeway
  22. 05 ex stalled while idleing
  23. Burning from Power Window Switch '02 LX
  24. cold air from heater
  25. Issue in car starting after reset SRS Honda Civic 2005
  26. Can the wire/plug be reused for the O2 sensor?
  27. 2002 Civic EX Vtec - thermostat bad?
  28. 2005 civic lx heated O2 sensor no voltage
  29. 02 Civic LX running with NO OIL. HELP!
  30. Automatic trans suddenly leaking like sieve
  31. Coolant leaking quickly after replacing thermostat
  32. How to find a good torque converter?
  33. Is it ok to use a scissor jack instead of a floor jack?
  34. What's the deal with 7th gen honda head gaskets?
  35. 03 civic ex squealing noise, smoke and rubber smell in cabin?
  36. Advice needed, 02 Civic EX p0304 and other issues
  37. Car Overheating with new headgasket, Need Help!
  38. help car will not start 1.6 sport 2005
  39. Pulley moved while changing harmonic balancer
  40. Code 1753 and Flashing "D" Light.
  41. What's a better manual for a 03 civic. Haynes or Chilton?
  42. 2001 honda civic cluster problem - registering 30mph over.
  43. headlight bulb fixture (Swiss civic)
  44. 2003 Honda Civic Hybrid (HCH) - rotten egg smell - no CEL
  45. misfire 2002 honda civic
  46. Front end drivers side noise
  47. no hot heater air on feet, blows fine/hot on panel and defroster
  48. Noise coming from under hood- Help!!
  49. Have 2002 honda civic need help
  50. 2002 Civic LX - Air stuck on main vents
  51. Automatic door locks 2001
  52. Lost a Lic, Key & Fob. How to secure the car now?
  53. Noise while steering, missing boot
  54. 2004 Honda civic hybrid A/C clutch wont engaged
  55. Brake Pedal Squeak
  56. Both windows stopped rolling down, and power locks wont work.
  57. First post, first Honda
  58. Can I swap an 04 LX D17A1 cylinder head onto an overheating 05 EX D17A2 VTEC ?
  59. P0740 & P1298, but only if I let it go to fourth gear?
  60. 2001 Head gasket Again?????
  61. 2001 civic EX...door hinges?
  62. Need a new transmission
  63. my 2001 civic dx iddles
  64. Blown motor, need help!
  65. Front bumper "guard" fell off... do I need to replace it?
  66. idle issue (already solved but worth a read)
  67. One headlight won't work
  68. 2002 Civic EX Vtec - transmission just quit
  69. Ordered Honda LH door lock cylinder...
  70. Metal support behind hood latch snapped -- can't shut hood!
  71. Strange belt or pulley noise. Trying to diagnose.
  72. oil splatter on valve cover
  73. Burnt valve 03 si
  74. Manual gearbox shifting into 1st and reverse problem
  75. 2003 civic ignition wont turn
  76. Where to start maintenance... 02 auto
  77. "Help me!!" body work needed
  78. car idle erratic once warmed up
  79. Steam from under the hood
  80. How to removal 2003 Civic DX sedan drivers side door panel?
  81. Is there any way to lubricate door lock actuators without replacing?
  82. 2004 Civic Blower Motor Issue
  83. 2004 1.7L valvetrain noise
  84. Vibrations coming from 2001 Honda Civic Coupe
  85. Vital fluids
  86. Door panel repair
  87. Intermittent P1519 code
  88. Won't start sometimes
  89. Misfires and codes with low gas level
  90. Overheating Issues
  91. Whats the 411 on your Head at the Machine Shop?
  92. flooding issues
  93. 2002 Honda Civic Ex AC Issue
  94. Head Gasket kit -Felpro Good?
  95. Clutch won't disengage
  96. 2005 1.6 sport petrol help needed braking and starting
  97. Cracked Exhaust Manifold.
  98. High pitched noise coming from the car.
  99. JonK
  100. Motor and Transmission Mounts?
  101. Clunk into Drive.
  102. Should I fix it or sell it?
  103. DRL On
  104. 2002 honda civic ex
  105. help! high revs slow acceleration and noise(video)
  106. possible purchase of 04 civic si.
  107. 2003 Honda Civic EX - Head Gasket? (Yes, I read the sticky)
  108. over heating
  109. Starts with starting fluid, runs ok, but won't start on it's own
  110. Dashboard lights and tail lights are out
  111. Always cranks, occasionally won't start
  112. Civic Issue and a Grad Student
  113. Overheating issue after I drive over 70 mph???
  114. Unsolved front passenger clunking noise after new parts
  115. 04 Civic "overheating"
  116. Transmission issues...
  117. Rear wiper won't stay up
  118. Front Door Lock Cylinder
  119. 01 Automatic Civic Oil leak
  120. Correct oil pan??
  121. 03 Civic bogging issue
  122. Car overheating
  123. Headlight/ignigtion buzzer not working
  124. P2646 code 2005 civic, vtec not kicking in yo
  125. I thought it was the Crankshaft Sensor
  126. Never heard of iridium plugs with gaps like this
  127. Gauge Cluster Lights Replacement fail, Burning Smell, Now Temperature Nobs Screwed Up
  128. how to get evap monitor ready?
  129. Unknown fault code. Might be clutch?
  130. Transmisson???
  131. What to do with my centre console '04 EM2
  132. Coolant and oil loss no overheat
  133. Emissions System – Small leak detected question
  134. Engine Bottom Fully Covered?
  135. 1st 3rd and 5th gear. Need ANSWERS!
  136. Differential axle bearing
  137. Increased resistance in left side seat belt tensioner
  138. Starts then dies!!! Help
  139. Low compression
  140. 2004 lx starting problems
  141. p0420 catalyst below threshold question
  142. Do I have to remove the front o2 sensor when taking transmission?
  143. turn signal harness ?
  144. 2001 civic ex possible tranny problem
  145. Hissing sound
  146. Replacing Clutch line with steel braided Lines
  147. Where do you buy parts? Spec AC compressor?
  148. Door stuck locked
  149. Possible Cam Sensor Problem?
  150. overheating
  151. Temp Gauge Working/Not Working
  152. Head gasket questions
  153. 2003 Civic Completely Locked up
  154. P0135 - HO2S Heater Circuit Malfunction Driving Me NUTS
  155. 2001 Civic EX coupe manual trans with sputtering idle?
  156. 2001 ex Coupe A/C issue
  157. 2002 Civic alt/battery?
  158. Starting issues
  159. Replacing SRS Parts
  160. clicking noise while braking
  161. Violent Shake
  162. 2001 EX Alternator issue
  163. O2 Sensor / Recurring Check Engine Light
  164. 2002 civic brown foamy substance
  165. Alternator or battery
  166. AC Question
  167. Intermittent weird engine noise
  168. 2002 Honda Civic mysterious dash issues
  169. Headlight problem - help!
  170. 2002 Honda Civic with PO113 Code
  171. Trunk won't close
  172. 2002 EX A/C issue. Thermal protector?
  173. Dead battery, need to reset immobilizer?
  174. 01 auto jerking at higher rpms
  175. 2002 1.7 no oil in filter with 4,000 mi. on it?
  176. 2003 Civic EX Auto, oil burning problems.
  177. Clicking noise when braking
  178. power steering pump too high...
  179. Help Solve Mystery! Extra bolts from Head Gasket & Timing Belt
  180. intermitant running
  181. Turn Signals not working
  182. Fuel Injector Unplugged for 3 weeks, now running very rough
  183. 04 Civic "redlines" at 4000rpm
  184. what is this ? 2001 ex
  185. Broken Left Engine Mount Bracket
  186. 01 civic has P0141 dtc
  187. Drain Hose Missing?
  188. 04 civic ex head gasket or cylinder head cost
  189. Engine burning oil
  190. Rough Shaking Idle (occasionally)
  191. MICU replacement question
  192. 2004 Civic EX intermittent fuel gauge problems.
  193. Starting Problems after Timing Belt Change
  194. 2005 Civic Screeching Sound Under Load (Video)
  195. Direct injection..save you up front but gets it back at the end?
  196. Hardest Speed Sensor Problem Ever
  197. A/C Problem
  198. 3M Roloc for aluminum?
  199. Transmission Fluid
  200. I think I damaged my transmission...
  201. Fuel pump cracks and replacement
  202. Correct O2 Sensor?
  203. 2002 Coupe LX Bumper
  204. Honda Civic 2005 check engine light ON
  205. programming key at the dealership difficult? Civic 2001 LX
  206. civic chick overheating after a long trip! 2005 SI EX
  207. Warped front rotors.
  208. 03' Civic DX - Ignition key not turning
  209. is this a CV Joint issue ?
  210. Improve MPG on 2001 LX
  211. 2001 LX Timing Belt Kit
  212. Power locks not working, key fob is
  213. Help Appreciated! - Chasing Mechanical Issues
  214. Stubborn Castle Nut
  215. 03 civic ex runs rough, rattles and dies
  216. 2001 Honda Civic Dashboard Problems
  217. a/c top up issues
  218. Fuel Fill Neck Question
  219. Odd lding issues, RPM drop off and excessive vibration
  220. wheel bearing replacement cost?
  221. Intermittent Horn Going Off
  222. Another muffler question
  223. power windows, 2001 civic sedan
  224. resetting trip meter in 01 civic ex button not responding
  225. A/C compressor bolt broke
  226. 2003 Honda Civic Hybrid MPG drop
  227. Suspension
  228. 2004 civic ex A/C not working properly
  229. 04 si Hb BB's in the engine!
  230. check engine light code P2646
  231. 97 civic
  232. 2002 Transmission Problem
  233. putting the cam shaft and rocker arm assembly back on the head
  234. Help identify part in head gasket set
  235. empty trunk
  236. Aftermarket Struts Ok?
  237. Clacking sound when starting car
  238. Need opinion on if car repairable.
  239. Weird Noise Like a Remote Control Car
  240. Guys please help!!!!!!!!
  241. Is this a blown headgasket?
  242. 02 civic starts, then stalls...
  243. AC Compressor Issues
  244. 2001 w/ a million problems, my options?
  245. Overheating and code p0128
  246. 04 civic ball joint/control arm replace
  247. What is this!!!
  248. So My Timing Belt Snapped....
  249. '04 Honda Civic Overheating.. please help
  250. Creaking noise on 2002 Civic Sedan
