A/C compressor bolt broke
One of the bolts that hold the A/C compressor to the mount snapped off when I was loosening it. Has anybody had this problem and would it be fine if I just put it back on with only 3 bolts?
Re: A/C compressor bolt broke
I'd fix it.
Remove the bracket.
Drill out the broken bolt.
Repair/restore the threads if necessary and replace the bolt.
If you don't have the finesse to drill on center and save the bracket, take it to someone who can.
Remove the bracket.
I did try and drill it out but I was off just a little and if I tap it the hole will not line up and allow the bolt to go in. Do you think there would be a problem with just 3 bolts holding the compressor on?
muttleytm
Jul 14, 2015 05:31 PM
beeemerdude
Jul 10, 2015 09:22 PM
