oil splatter on valve cover
Old Nov 27, 2015
vdubbin95's Avatar
vdubbin95 is an unknown quantity at this point
any ideas why oil is covering the corning of my valve cover, i wipe it off and it returns. everything seems to be tight. Click image for larger version
Old Nov 27, 2015
mikey1's Avatar
Re: oil splatter on valve cover
your spark plug seal could be shot in that cylinder,
could be valve cover gasket,
or a leak in the timing area such as camshaft seal,
those are really the only possibilities in that area
Old Nov 27, 2015
Remove plastic cover, remove ignition coil, look for a source.
Old Dec 2, 2015
thisguy357's Avatar
thisguy357 has a spectacular aura aboutthisguy357 has a spectacular aura about
just to add to the previous comments, AFTER you find your oil leak and fix it. Check your PCV valve.. when they stick closed it allows pressure to build up in the crank case and you will start pushing oil out of your weakest seals
Old Dec 2, 2015
Mad Dog Tannen's Avatar
When I bought my car, it was missing the rubber o ring for the oil cap. The owner couldn't figure out where the oil was leaking from. Probably the fastest diagnosis and fix I have ever done ever!
Old Dec 2, 2015
mikey1's Avatar
could also be the seal around one of the valve cover bolts
83rs50
Jan 14, 2016 12:38 PM
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
redrocket87
Bolt-on Engine Performance
Nov 27, 2015 07:32 PM
Cmiller
Nov 26, 2015 08:33 PM
Fox350
Nov 24, 2015 05:50 AM
