One headlight won't work
Old Nov 30, 2015
sidelines321's Avatar
sidelines321 is an unknown quantity at this point
After doing some work on my 2001 Civic LX this weekend, including removing the battery, I have the following issues with my right headlight:
Low Beam does not work
Parking lights do not work
However the following works:
High beam works
Turn signal works
Hazard lights work
I have checked the fuses and there are no problems. I switched the fuse for the left and the right and the left still worked. I switched the left and the right relays. The left still worked. I have power to the wiring harness. When I turn the switch on for the low beams I get 12V at the harness.
I am thinking I did something to the ground for the headlight. Is the ground for the low beam and parking lights connected? Is there something other than the ground that could cause this?
Old Nov 30, 2015
GolNat's Avatar
Prelude Owner
Re: One headlight won't work
Well your low beam is a seperate element from your high beam so you may just need a new bulb. One bulb does both high and low. Did you check the filament?
Parking light bulb could also be bad. Check the filament and connector. There is a ground location on the frame under the light but if all you did was remove the battery those should not have been disturbed.
Old Nov 30, 2015
mikey1's Avatar
test the ground at the connector,
connect the negative of a voltmeter to the ground at the connector, and connect the positive of the voltmeter to the + battery post, you should get a reading the same as your battery voltage,
change the bulbs from right side to left side?
Old Nov 30, 2015
Which is the ground at the connector? I saw red/blue, red/white and red/yellow at the connector for the headlight. I am used to seeing ground as being black. My next step is to change the light. It was dark outside last night when I was trouble shooting.
I did look at the bulb. It looked good, but I will switch it to make sure.
Old Nov 30, 2015
CraigW's Avatar
RED/YLW is 12V common to H & L filaments.
RED/WHT is grounding path for low beam.
RED/BLU is grounding path for high beam.
Old Nov 30, 2015
What work did you do, exactly?
Anticrosswalk
Jul 21, 2015 01:37 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
bambuski
Nov 12, 2001 10:35 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
Lightman
Nov 10, 2001 06:44 PM
