2001 LX Timing Belt Kit
Old Aug 11, 2015
Ray Darvi's Avatar
Ray Darvi is an unknown quantity at this point
I'm going to buy whatever needed for a complete timing belt change from Majestic Honda. Emailed them asking what needs to be purchased and replaced and got this list:
CAM SEAL...... 91213-P2F-A01
TIMING BELT...14400-PMM-A02
CRANK SEAL....91212-PLM-A01
WATER PUMP..19200-PLM-A01
P.S. BELT.......56992-PLM-003
A/C BELT........38920-PLR-003
TENSIONER.....04145-PLC-315
When I looked up timing belt kit, there are so many different combinations in the kit and not sure if the list is overkill (oversell) or missing something.
I need to purchase all that'll be needed and have a local mechanic shop do the replacement and don't want to allow them to trick me with Oh this part is needed and you didn't order it, and charge more or install crap on the car.
Old Aug 11, 2015
GolNat's Avatar
Prelude Owner
Re: 2001 LX Timing Belt Kit
That's looks like a good list. It's the kind of job that once you have stuff apart it's best to replace things like the cam and crank seal.
The tensioner can be inspected and may not need to be replaced but if it fails it is an expensive fix so I would replace it.
Old Aug 11, 2015
emich's Avatar
emich is an unknown quantity at this point
Don't forget longer bolt for the tensioner https://www.civicforums.com/forums/36-mechanical-problems-vehicle-issues-fix-forum/364839-03-civic-ex-runs-rough-rattles-dies.html
Old Aug 11, 2015
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Originally Posted by emich
Don't forget longer bolt for the tensioner https://www.civicforums.com/forums/3...tles-dies.html
Anybody have info on the longer bolt? PN maybe?
Old Aug 11, 2015
GolNat's Avatar
Prelude Owner
Not sure why a longer bolt is needed. Mine used the regular bolt and was fine.
Old Aug 11, 2015
emich's Avatar
On the end of the link above there is info about the longer bolt.
Old Aug 12, 2015
Ray Darvi's Avatar
This is what Honda rep replied back to me:
There is only one tensioner bolt available. Honda updated the part, so they updated the part number. The only part number available is 14517-PLC-013.
So PN is 14517-PLC-013, and Honda already upgraded the part to longer one.
mattdoc
Mar 14, 2017 12:10 PM
Supramk3
May 11, 2015 07:55 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
