Do I have to remove the front o2 sensor when taking transmission?
Old Sep 19, 2015
blizza's Avatar
blizza is an unknown quantity at this point
Hi everyone. I have a 2003 Honda Civic Ex automatic, and am going to be fixing my transmission. My question is, do I have to take out the o2 sensor to do this, or is there another way? Thanks.
Old Sep 19, 2015
Re: Do I have to remove the front o2 sensor when taking transmission?
Unscrew it and let it dangle?
Unplug it so the wire doesn't get pulled?
Leave it in place.....and if it gets broken then you'll know why it needed to be removed?
I don't remember having to remove it, but it's been a long time since I had to pull a trans on a car that old....and I forget stuff.
Old Sep 22, 2015
mac25's Avatar
Dr Krieger of Modification
Up stream is fine just unplug it, down stream I tryed to unplug it and it was a bitch so I snapped off the connector mount then zap strapped it when reinstalling.
You also have to unbolt the header and slide the exhaust back plus remove the sub frame if you are coming out the bottom.
from the bottom you don't need to remove the engine which means you can leave your coolant and ecu harness connected.
Old Sep 22, 2015
mac25's Avatar
If you do remove the sub frame may the four corners then when you reinstall the alignment should be closer to when you pulled it out.
siliconvalley
Sep 15, 2015 09:48 PM
pfwel1977
Sep 10, 2015 02:16 PM
tommycanada
Sep 5, 2015 04:59 PM
