Dashboard lights and tail lights are out
Old Oct 18, 2015
WillEl1.7's Avatar
WillEl1.7 is an unknown quantity at this point
Hi, I have a 2001 Acura el 1.7,
Both the tail lights and the dashboard lights are out all other lights are working I've checked the fuses and they're all good, resoldered the drl control module did not fix problem. Anyone got any ideas on how to fix this problem?
Old Oct 18, 2015
CraigW's Avatar
Re: Dashboard lights and tail lights are out
Fuse called "small lights"
Do you hear a single click from under drivers side dash when switching to parking lights ??
Old Oct 18, 2015
Fuse #2 (15A) in the engine compartment
Headlight switch
Taillight relay in the dash fusebox
A good wiring diagram and some test equipment (probably just a simple test light) would be in my next plan.
Old Oct 18, 2015
WillEl1.7's Avatar
Thanks it was the small lights fuse, the only one I didn't check.
Old Oct 20, 2015
WillEl1.7's Avatar
The fuse keeps shorting worked for a day now it shorts immediately
Old Oct 20, 2015
WillEl1.7's Avatar
Headlight switch
Where would I find a wiring diagram?
Old Oct 21, 2015
Search, start on the last pages of this long thread first
https://www.civicforums.com/forums/182-7th-generation-civic/235295-looking-7th-gen-manual-free-updated.html
Try your local library, many have access to Alldata and/or Mitchell service info.
Pay subscription on Honda Service Express
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
califcamper
Jul 21, 2015 10:34 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Boostgst
Jun 29, 2015 11:38 AM
Mike Garvey
Jun 7, 2015 07:25 PM
