2001 Civic no crank no start.
Old Jun 7, 2015
Mike Garvey's Avatar
Mike Garvey is an unknown quantity at this point
Hey all.
First time posting here looking for a little help. Car was driving fine no issues. Parked it for a day and then it wouldn't crank. When I release the key the needles go absolutely nuts and there is a ton of ticking. I've checked the fuses and they seem fine. Didn't see any blown ones relating to the alternator or ignition system. When I turn the headlights on the under hood fuse box ticks and I can feel the ticking in the ig1 fuse. Tried boosting but no luck. From what I've seen online it could be the battery alternator or starter. What's the best way to proceed here?
Old Jun 7, 2015
mikey1's Avatar
Re: 2001 Civic no crank no start.
disconnect battery,
test battery voltage,
12.5v or higher proceed,
12.5v or lower replace battery then proceed,
clean battery posts and terminals/connectors spotless with a mixture of water and baking soda,
dry terminals off,
reconnect battery and try again,
Old Jun 7, 2015
It worked. Battery tested great. Corrosion on ground clamp. Starts. Thanks a ton.
mattdoc
Mar 14, 2017 12:10 PM
bambuski
Nov 12, 2001 10:35 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
