Stubborn Castle Nut
Old Aug 9, 2015
manfredww1's Avatar
manfredww1 is an unknown quantity at this point
Stubborn Castle Nut
I have been trying to remove this castle nut below my ball joint for the past 48 hours. I have tried specialty sockets which dig into the nut, those do not work. I have tried soaking the nut in PB Blaster and then using vice grips. All I am doing is rounding off the nut as you can see . I was thinking of trying a cold chisel but I really do not want to damage the bolt .If I did use a chisel how would I go about it. Any suggestions or other ideas?
Old Aug 9, 2015
Bran's Avatar
Bran is an unknown quantity at this point
Re: Stubborn Castle Nut
If you can still grip it, heat up the nut until it is red hot then crank on it should come right off. You can pick up a torch at home depot. If you cant get a grip on it might want to try a nut spliter.
Old Aug 9, 2015
manfredww1's Avatar
I read that heat near the ball joint will make the boot on the ball joint melt . Do you think a nut splitter will fit in that location?
Old Aug 10, 2015
Bran's Avatar
Yes heat is bad near ball joints and bearings... But so are stripped nuts lol. From your pic it looks like you should have room for the splitter.
Old Aug 10, 2015
GolNat's Avatar
Prelude Owner
I would torch it.
Old Aug 10, 2015
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Did you remove the cotter pin? It looks like it is still visible in the 1st picture.
Do not heat balljoints that you plan to reuse. Do not heat balljoints that you do not plan to reuse. Heat can make a ball joint explode with enough force to throw pieces of steel through metal siding. I would use a grinder with a cutoff wheel to slice through the nut. With care you can cut the nut without damaging threads.
Old Aug 10, 2015
Search youtube for exploding ball joint
Old Aug 10, 2015
mcnoople's Avatar
Here is one that is NOT for the squeamish. It is a surgery video and for those that don't recognize the item, it is the flat metal plate at the top of the ball joint.
The morale of the story DO NOT HEAT BALLJOINTS EVER.
Old Aug 11, 2015
emich's Avatar
emich is an unknown quantity at this point
Get your pipe wrench. Do not heat it.
Old Aug 15, 2015
j_dock69's Avatar
j_dock69 will become famous soon enough
Ball joints are cheap and easy to replace, cut the nut and the bolt you panzy
Old Aug 17, 2015
mac25's Avatar
Dr Krieger of Modification
...stop f'in around, buy two new ball joints, a tie rod separator and an angle grinder.
believe me it will save you sooo much time and effort.
Cut right through the castle nut and the threaded lower portion of the ball joint, then use the tie rod separator, then a hammer to smash the remains of the ball joint out.
then install the new ones.
Old Aug 17, 2015
mikey1's Avatar
get a grinder and cut it off,
don't tell me you are planning on re-using it at this point
i dont see how this is possible if you were using the correct size socket to begin with
Raiool
Oct 1, 2015 10:42 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
Hollywoodsnake
Sep 20, 2015 12:58 PM
stank
Sep 16, 2015 07:40 AM
