Noisy valves for a few seconds on cold starts (usually)
Old Jan 27, 2016
Neutrino's Avatar
Neutrino is an unknown quantity at this point
2007 Civic Si, no mods other than a stainless exhaust (headers to tips) and a stereo w/ bass.
Usually, when it is cold (well, not been run for several hours), it will sound like a diesel for a couple of seconds when it starts. The valves seem to be WAY noisy, but only for a moment - not long enough to do much aside from notice it. If you shut it off, then restart, it purrs like usual. It is only the first start that is noisy.
I've had this car less than a year, and I had a thorough mechanical inspection done before buying it. The mechanic found almost nothing wrong with it, and nothing in the engine.
The sound doesn't really bother me, but I want to know that my beloved car is not damaging itself. Any idea WTF it is?
Old Jan 27, 2016
Re: Noisy valves for a few seconds on cold starts (usually)
2 or 3 possibilities come to mind:
Chain tensioner rattles until oil pressure builds up,
Chain tensioner is bad and rattles until oil pressure builds up
or the VTC actuator (intake cam gear) rattles until oil pressure builds up.
I'd probably want to make sure the chain isn't stretched and the tensioner hasn't stripped its teeth----it's supposed to ratchet out and should lock, it should not allow its plunger to go all the way back in, which would allow the chain go slack and possibly jump time.
Rob02Civic
Jan 21, 2018 02:06 AM
pranav
Transmission
Apr 11, 2016 04:02 PM
ravenator
Jan 21, 2016 09:22 PM
chohan
Jan 19, 2016 09:23 PM
adityacivic
Jan 16, 2016 09:21 PM
