is this a CV Joint issue ?
Old Aug 11, 2015
mrohitredd's Avatar
mrohitredd is an unknown quantity at this point
Pulling out of my drive way, steering complete left while reversing the car, i hear a knocking sound from under the car. Researched a bit, is this a CV Joint issue ?
Is there a DIY article for this... been searching & could not find one...
2002 - LX - 4Dr Sedan - Auto Tran - 1678k miles
Thanks.
Old Aug 11, 2015
emich's Avatar
emich is an unknown quantity at this point
Re: is this a CV Joint issue ?
Thanks.
Could be broken sway bar link
Old Aug 11, 2015
Got a recording of the noise?
Old Aug 11, 2015
GolNat's Avatar
Prelude Owner
Does it make the sound complete left going forward?
https://www.civicforums.com/forums/1...riveshaft.html
Old Aug 12, 2015
mrohitredd's Avatar
I replaced them very recently... checked them & still looks in good shape.
My wife drives the car during weekday, to go to work... i'll try to record the sound & put it here...
I havent noticed that... Heard the noise only while backing up.
Great write up by the way .
Old Aug 12, 2015
A bad outer CV joint will usually (not necessarily always) make a pop sound or a ratcheting sound that coincides and repeats with each wheel revolution.
Also usually (not necessarily always) it is louder or worse when the wheel is in a tight turn and you are accelerating, as in taking off from a stop (large load on the joint)
GolNat
Suspension DIY
May 12, 2022 06:49 AM
chuffsy
May 15, 2015 12:50 PM
El_Spic
Apr 23, 2015 03:14 PM
sorphin
Mar 19, 2002 02:35 PM
insan
Transmission
Jan 7, 2002 04:04 PM
