2002 honda civic ex
Old Oct 22, 2015
greatguy49's Avatar
greatguy49 is an unknown quantity at this point
2002 honda civic ex
hi i have a 2002 honda xcivic ex with 320 000 kms on it but latetly its been feeling a little sluggish probably an oil change and plugs might do it just wondering what too do any suggestions please
Old Oct 22, 2015
Poopies's Avatar
Super Moderator
Re: 2002 honda civic ex
Well, how old are the plugs and oil? What have you done to the car, as far as maintenance?
Old Oct 22, 2015
greatguy49's Avatar
not sure just got the car a little while ago about a month or so ago i havent changed the oil yet or the plugs but i dont want too do it until i know for sure wat is causing this problem the car had had regular maintenance oil changes ie for many years already wen i got it seemed more perkier pickup was better it just seems sluggish too me not like it was before do you think oil change and plugs will make a big difference
Old Oct 22, 2015
greatguy49's Avatar
the maintenance required light flashes wen i start it so it needs something but everything else on the car seems fine
Old Oct 22, 2015
Mad Dog Tannen's Avatar
Do ALL preventative maintenance in the manual. That should get it back up to par.
Old Oct 22, 2015
Poopies's Avatar
Super Moderator
+1 to that. If you didn't do it and there isn't a detailed record, you might as well consider it as not being done. That goes doubly true for the timing belt. Consider that a PRIORITY if the previous owner hasn't had it done.
Old Oct 22, 2015
greatguy49's Avatar
yes the timing belt was rep;laced by previous owner not long ago so thats ok i guess it just needs regular maintenance then it should be fine thanks
Old Oct 22, 2015
That's just the oil change reminder.
Is the check engine light on? Got codes?
Old Oct 22, 2015
greatguy49's Avatar
no the check engine light is noit on at all just needs basic tune up im sure that will makle a big difference
Old Oct 22, 2015
greatguy49's Avatar
wat happens if i ignore the oil change past the time its supposed too be done would that cause the sluggishness in the engine could need an air filter or fuel filter changing also i guess i heard you can buy fuel injector cleaner too run through it you can put it in the gas tank wen its almost empty do you think that will help
Old Oct 22, 2015
Poopies's Avatar
Super Moderator
It COULD, but the oil would have to be REALLY old for it to noticeably affect the engine.
Probably.
Maybe. Try that after the basic maintenance gets done.
I used to use Techron every other fill-up before I started using my current additive. Try filling up at Top Tier gas stations only. A lot of us do when it's practical.
Do your basic maintenance on the car first. Then reset the maintenance light. It's super easy to look up and do.
Old Oct 22, 2015
greatguy49's Avatar
ok thanks yes thats true well i will do that anyway i guess and possibly it could be the plugs not sure wen they were done last it will surely help anyway
Old Oct 22, 2015
greatguy49's Avatar
would you say it would be ok too change the oil and filter and plugs on my own or just take it too garage and let them do it also would oit be a good idea too get it hooked up too a scope as that will tell them and me where the fault lies if any and if thats clear then i will know
Old Oct 22, 2015
Do what the manual says, if you don't know if it's been done recently, then do it. There is a list/graph of scheduled maintenance items in any manual for that car, DO ALL ITEMS, filters are on that list.
Old Oct 22, 2015
Now THERE is a term I haven't heard in about two decades!
I really hope you weren't thinking of one of these monsters.
Nobody ever knew what the hell those were really for, but they looked damn impressive when hooked up to a car and therefore justified a lot of money on the bill..
Old Oct 22, 2015
Poopies's Avatar
Super Moderator
Did YOU use one of those?
Old Oct 22, 2015
Short answer: Yes.
fafa1234
Aug 8, 2015 06:42 PM
Chancé Doucet
General 7th Gen
Aug 8, 2015 04:54 PM
amrhamed
Aug 7, 2015 11:39 AM
knknif
Aug 4, 2015 06:11 PM
Ronin Nishimura
Jul 28, 2015 07:24 AM
