Honda Overheating
Honda Overheating
Got a 2000 Honda Civic LX. Temp gauge needle will go up past the middle after driving around for a while. I've changed the radiator and water pump. But I haven't changed anything else. I don't know much about cars, so I'm completely stumped. Anyone got any ideas?
Re: Honda Overheating
do these levels ever change drastically?
Check your thermostat. If its not closing like it should be. That will cause overheating. Locate the upper radiater hose... You cant miss it.. DONT DO THIS IF THE ENGINE IS COLD. ( WARNING-wear protective gloves like an over mitt ) bring the car up to operating temp. Then sqeeze that upper hose.. When you release the hose you should feel a rush of coolant. Thats one way to know if its working. Next is to locate the thermostat itself and take it out and put it in boiling water to see if it opens at the right temp. But try the first way first and let us know. ALSO CHECK YOUR COOLANT LEVEL AND OVER FLOW TANK. DO THOSE FIRST.
It usually occurs after I've been running the car long distance, the air con is running, and I've come to a complete stop. The coolant will shoot into the overflow bottle and the needle on the gauge will go up. It goes back down after I've turned off the air con and am moving again. But the coolant has to be refilled.
There are 2 fans in the engine compartment....One for the AC, the other for the radiator. Does the radiator fan run? Is it running while the radiator tank spews antifreeze and overheats?
Overheating leads to head gasket problems and possible engine damage.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
hokiedad4
May 3, 2015 10:06 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
