Burning from Power Window Switch '02 LX
Old Jan 21, 2016
NathanKeller's Avatar
NathanKeller is an unknown quantity at this point
On the way to school this morning I rolled down my passenger side window and when I arrived it wouldn't roll back up. I smelt a burning smell from the drivers side window switch. I checked the fuses, and the Passenger Power window fuse was blown, so I replaced it. Still smelling the burning smell, and the window will still not roll up. All the other windows work fine. I read somewhere that if this driver's side switch fails that the windows will not work at all, is it the switch on the drivers side that is bad?
Old Jan 21, 2016
CraigW's Avatar
Re: Burning from Power Window Switch '02 LX
Those master switches are known to self destruct.
Is the new fuse still intact ??
Old Jan 21, 2016
Just checked the new fuse I put it, and it is busted.
Old Jan 21, 2016
CraigW's Avatar
Try to determine when fuse blows.
Ignition at II,...? or when attempting passenger window ?
The single window switches when at rest pass the +&- or -&+ from the master switch to the motors.
https://www.civicforums.com/forums/a...7&d=1350598426
Old Jan 21, 2016
Update, I pulled the drivers side door off and clearly it was the power window switch that was causing the burning smell. Got the replacement part from NAPA, and I installed it and it fixed all issues.
Old Jan 22, 2016
CraigW's Avatar
Thanks for update, this seems common on 7ths.
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
thesushiboy
Transmission
Nov 3, 2015 04:57 PM
thesushiboy
Lighting
Nov 2, 2015 05:42 PM
dave343
Oct 31, 2015 11:39 PM
Lopezsoul
Oct 29, 2015 08:30 PM
