2001 civic EX...door hinges?
Im sure most of you have had this happen or will soon.. the drivers door wont stay open like the hinges are worn out... is there anything I can do for this? or do you just have to replace the hinges?
thanks
thanks
Re: 2001 civic EX...door hinges?
The doors use plastic & rubber "checkers" to hold the door slightly at certain points.
If worn, they would allow the door to not stay put as it should.
Most of the cars have them installed from inside the door, you would have to at least pull the door panel off to reach it.
bolts are probably on the outside though. Open your door and take a look.
bonestockcivic
Dec 4, 2015 10:37 PM
MamaBear2015
Dec 3, 2015 08:52 PM
h4ldol
Dec 1, 2015 12:55 PM
