01 civic has P0141 dtc
Old Aug 21, 2015
Dmer's Avatar
Dmer is an unknown quantity at this point
My 01 civic has the dtc P0141 on and can't figure it out . Both 02 sensors are new , check the heater circuit out and have 12v and ground , has there been an issue with the ecms on these cars
Old Aug 21, 2015
Re: 01 civic has P0141 dtc
New from where? What brands of sensors did you install?
You replaced BOTH sensors for this code?
Have you rechecked codes, do you have codes for both sensors now?
Got your original sensors? What brands were they?
Old Aug 21, 2015
Dmer's Avatar
Bought the car and it had both new sensors in it not sure what make , have a parts car with no codes on it so I changed out both the sensors from the parts car . Still same code , checked and compared the voltage and resistance readings with my parts car . They all check out the same . Thinking it is the ecm . When I watch the live data on my code reader the number never change for the down stream 02 sensor .
Old Aug 21, 2015
What year is the parts car?
Ohm test the heater in each sensor. What resistance does each sensor show?
Rear sensor heater should be 10-40 ohms
#4 fuse (10A) in the dash fuse box good?
Old Aug 21, 2015
Dmer's Avatar
The heater circuit in the sensor is 12.2 ohms , engine is cold , checked all the fuses under dash , fuse 4 under dash says its for the alternator . But it is good
Old Aug 22, 2015
I've got one note that says a rear sensor from an 05 tested at 15.6 ohms hot, so that sounds ok.
I personally have not had to replace a PCM for a code like this, but I work at a small dealer.
Old Aug 22, 2015
Dmer's Avatar
The parts car is a 03
Old Aug 22, 2015
Dmer's Avatar
Checked the resistance in the heater circuit on the new sensor that came with the car only 7.8ohms
Old Aug 22, 2015
That resistance does not sound ok.
ezone
24
Oct 30, 2017 11:27 AM
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
Lightman
Nov 10, 2001 06:44 PM
WeRkX
Nov 1, 2001 10:33 PM
