Fuel pump cracks and replacement
Old Aug 13, 2015
Chatito's Avatar
Chatito is an unknown quantity at this point
My 2002 honda civics fuel pump has little cracks on the white plastic area where the wires and the tube are connected.. Well I need help.
Im not really sure whats best for me to do, if buyin the whole part"the fuel pump filter" or getting just the plastic part where the cracks are?? And if its not much to ask.. can someone reefer me on where is the best place i should get those pieces.... Thank you
Old Aug 13, 2015
Poopies's Avatar
Super Moderator
Re: Fuel pump cracks and replacement
Moved to 7th gen and deleted the other post. Do you have pictures of the cracks?
Old Aug 13, 2015
Chatito's Avatar
It splashes gas thru the cracks when i start the car
Old Aug 13, 2015
Google drive---no permission to see the pics.
Replace the fuel filter set, swap your pump into the new filter assembly. (or buy the entire tank unit? $$$)
AFAIK Honda does not sell just the filter set, but you can find it aftermarket.
Be careful, many people seem to have troubles getting the O rings in the right place or the lines fully connected when swapping the pump over.
Old Aug 14, 2015
USCGBM's Avatar
USCGBM is an unknown quantity at this point
I have a 2005. the fuel pump assembly was much easier to replace than others I've done. Good luck!
CarStuff
Dec 6, 2020 12:52 PM
Jonnie.
Jan 13, 2019 11:21 AM
McD
Apr 22, 2015 05:28 PM
BREADFAN
Apr 15, 2015 08:58 AM
