04 Civic "overheating"
Old Oct 16, 2015
CoupeGuy04's Avatar
CoupeGuy04 is an unknown quantity at this point
Recently my Civic started reading that it was overheating. Sometimes when I'm at a stop the temp gauge climbs rapidly. As soon as I start moving the temp gauge drops back down to normal. I just changed out the thermostat to see if that solved it..but no. Thinking water pump? Please help.
Honda Civic 1.L 2004 Coupe
Old Oct 16, 2015
Poopies's Avatar
Super Moderator
Re: 04 Civic "overheating"
Is the fan turning on?
Old Oct 16, 2015
CoupeGuy04's Avatar
When it idles the fan does turn on and turns off after a min or so.
Old Oct 16, 2015
Your radiator is low. Refill it.
The reservoir bottle is overfull? Empty?
No leaks seen on the ground?
I smell another head gasket job.
Old Oct 16, 2015
gizmo97's Avatar
gizmo97 is an unknown quantity at this point
Nothing to do with this thread but I dont know how to start a new thread?
Old Oct 16, 2015
Poopies's Avatar
Super Moderator
First, search for your issue in (the likely) case it's been covered before. If you're still not satisfied, go to the subforum your issue falls under (like, 7th gen--->mechanical issues/fix-it forum) and the "New Thread" button will appear above the "threads in forum" section. Click that and you're good to go.
HTH
Old Oct 17, 2015
CoupeGuy04's Avatar
Everything is full, no leaks on the ground.
Old Oct 17, 2015
CoupeGuy04's Avatar
Yeah sorry, I'm new to this forum.
Old Oct 17, 2015
Poopies's Avatar
Super Moderator
Read this, it's really helpful.
https://www.civicforums.com/forums/3...reference.html
Old Nov 22, 2015
CoupeGuy04's Avatar
Lol turned out to be a head gasket
Old Nov 24, 2015
Poopies's Avatar
Super Moderator
Well, it is what it is. At least you shouldn't have to do it again!
Harding12390
Apr 6, 2018 11:43 AM
tomas6791
Jul 13, 2015 06:07 PM
Galvezj11
Jun 17, 2015 04:13 PM
si_me_now
Jun 3, 2015 09:19 PM
hans.pcguy
May 16, 2015 09:54 PM
