2001 honda civic cluster problem - registering 30mph over.
Old Jan 9, 2016
mike96gtvert's Avatar
mike96gtvert is an unknown quantity at this point
I am haveing a problems with my 01 civic ex.
The cluster is registering 30mph over that what Im actually doing. Even at idle it sits at 30 and goes up accordingly.
thanks.
Old Jan 9, 2016
Re: 2001 honda civic cluster problem - registering 30mph over.
needle position? if so will need open the dash/gauge and reposition
does it go down when the key is off?
Old Jan 9, 2016
thanks for the response.
when the key is off = hits 0
when key is engaged = hits 30
you see it falling down when you turn the car off.
Old Jan 9, 2016
Disconnect the battery cables and short them together for 10 minutes, then reconnect to battery and see if cluster still acts wrong.
If that doesn't change anything, I'd say it probably needs a cluster, or find a speedometer shop that repairs them.
Old Jan 9, 2016
whats cheaper? getting it fixed? or just buying a whole new cluster from flebay?
Old Jan 9, 2016
You'll have to do your own research on that.
There are a whole bunch of differences in clusters that aren't always readily visible so it's easy to run into issues if you don't do your research first.
Keep in mind, the odometer mileage is stored inside the cluster so if you get a used unit it will show whatever mileage was on the car it came out of. This could cause complications later on when you try to sell or trade if you don't have proper documentation of the change.
AND the speedo shop that might be able to repair a unit is also the place that can change the mileage in a used unit to match what's on the car now.
At work we use http://paspeedo.com/
HTH
Old Jan 11, 2016
i hear the milage is saved onto the computers main computer.
and not on the dash's cluster.
am i wrong?
Old Jan 11, 2016
am i wrong?
That would be wrong. Read again what I wrote in post #6.
Old Jan 11, 2016
read my post #7
Old Jan 11, 2016
read my post #7
I did.
am i wrong?
That information you heard is still incorrect.
Old Jan 11, 2016
got it. Cant i open up the cluster and just pop the needle off and on and reset it at "o"
Old Jan 11, 2016
Do the gauge cluster self test first, see if all the needles make a complete sweep from min-max-min during the test. It's been posted several times here somewhere, search for it.
You can try repositioning the needle, but it sounds like you probably have a bad stepper motor in the speedo.
Old Jan 11, 2016
Thank you for your help.
alinaray
18
Aug 24, 2015 01:04 PM
guy
Jan 6, 2002 04:39 PM
oblivious9
Jan 1, 2002 07:12 PM
TopFuel
Exterior
Nov 13, 2001 07:05 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
