- Alarm on 2000 Honda Civic Si
- 2000 Civic LX cruise control not working
- 1457 help....please
- Steering Wheel Vibration Under Braking
- New fuel injectors.. reset ECU?
- MY civic turned to a V8!!
- OBD2A to OBD2B issues
- Cranks but won't start (JDM B16B)
- Old battery - weird behaviour
- Low RPM Shake
- Strange idle and boggin' down.
- O2 Sensor 97 civic - change
- Plastic burning smell
- Rough/low idle and a misfire code
- B20B Help/Questions!!
- Weird coolant system problem (fixed)
- Question about 3X3 atf change
- 2000 Civic Junk Yard replacement Motor
- Blow head gasket
- 99 LX Temp fluctuation
- High Idle, then fluctuating, now high then stall? Getting Pissed!
- lazy trasmission
- Overheating issue help please!
- 97/98 NGK plugs
- Crank but won't start....Help!
- 99 LX Pinging bad
- 1998 Civic Ex Coupe Non-vtec automatic P0335
- Help me understand please!
- P0171 and P0170
- 1998 Honda Civic EX Mystery P0505 DTC
- Acceleration loss while driving, no CEL
- Battery light / Transmission question
- Mysterious overheating - completely lost
- new IAC?
- P0335 Cranksensor Malfunction A
- 98 Honda Civic ex
- 2000 Si smoking
- distributor question
- head gasket or pcv system?
- 2000 Civic hatchback d16y7.The AC compressor and something is smoking like a belt?
- 97 civic Ex won't pop into gear
- Help Identify Missing Part
- No Crank No Start
- Car jerks occasionally/cannot maintian speed
- 2000 Civic power lock
- auto gear lock won't disengage
- 1999 honda civic ex knocking noise and turns off
- Heat or air but not both
- replace motor or repair head.
- Failing Fuel Pump?
- Engine Cranks but no Spark Even After Dizzy Replacement Mystery
- Bought a 98 Civic - Question re Headliner and Locks
- '99 Civic No Crank No Start
- started and ran fine, then just stalled and wont restart
- Cel i just did tune-up misfire on all cylinders
- Chewing gum down parking brake gap
- engine shake/shutter at take off
- Question on Burping
- Car won't start
- transmission help
- Oil on plugs
- Oil leak and Idle issues
- 99 civic lx only starts when cold
- Rack & Pinion help!
- Broken Bolts That Hold Sway Bar Bussing Now What?
- Weird starting problems 97 civic ex 5 speed
- P0706 and P1456 codes
- Front Suspension : What Needs To Be Replaced?
- 2000 Honda Civic ex wont start
- 3500 rpm problem (Cps)
- 98 auto 1.6 intermittent loses power/sputters when cold, town and highway
- 99 Civic LX - TPS - Replaceable or no?
- Need help finding a replacement header/downpipe
- Need help finding Exhaust header/downpipe for a 97 civic
- Power loss, overheating and strange exhaust grind noise, Please Help!
- Ac compressor and condensor fan not turning on 2000 honda civic ek3
- Batteries keep smelling like sulfur
- Stop or Slowdown Oil Leaks
- 2000 civic died while driving, crank no start
- Fast shaking/Vibrating
- 1997 Camshaft Sensor
- p1381 code
- 14 mm crush washer for Civic drain plug?
- O2 sensor/ map sensor/ fuel metering system
- MAP Sensor caused check engine light to go on?
- 1998 civic ex belt lock up
- Oem quality parts for tune up (cap, rotors, wires)
- gggrrrhh Sound When I Take Off From 1st Gear
- honda civic LX '00 transmission shift at high RPM
- 6th gen EX. need to replace exhaust and need advice.
- no oil in filter
- Been a rough week ending with trans problem
- High idle in hot weather
- 97 civic hatch D15B VTEC problem
- Common O2 sensor problems
- Squealing belt when air conditioning is on
- Rear Creaking Noise
- 2000 Civic over heating
- A/C not working
- Is this an acceptable method to flush your radiator?
- What hoses are these?
- Sway bar links, 96 Civic Coupe
- fuel level sensor
- 1999 Civic won't shift out of park
- Exhaust rattle caused by failing water pump bearings?
- 1999 Civic automatic shifter sticky
- Oil leak
- 96 dx
- 98 civic lx ... Recently I've gotten a P0118
- P0135 and car almost dies when stopping
- Advice - "Tune up or not to tune up"
- catalytic cleaner
- P1259 on Mini me
- Oil leak
- Car Cranks But Will Not Start
- 99 Civic Overheating in Traffic
- D16Y7 Random Stuttering
- Wheel Hub Weirdness
- 1997 ex 1.6l vtech bent valve?
- Appropriate engine temperature
- How's this engine sound?
- Oil being airated
- Y8 ecu with a y7 engine
- Oil in Coolant after Head Gasket Change
- Fuel gauge help.
- '97 Civic EX Overheating
- Cooling System Nighmare
- My Engine Squeaks
- Car running warmer after head gasket change
- Sticky Throttle- Stopper Screw (with answer!)
- single knock on startup
- 97 civic crank no start has fuel spark and timing is on
- Reseat the camshaft seal without removing timing belt?
- 96 civic wont start
- Need a green light from the experienced to proceed
- 2000 LX, D16Y7 Sound
- Inner Tie-Rod End
- Reinstalling Cam w/o messing with timing?
- 98 honda civic wont start
- Z6 swap knock sensor code?
- Power Steering Fluid Leaking (Source Found)
- Replacing Engine on my 97'Coupe DX 5spd
- Crank no start
- Updates...The Return of the surging idle
- My 2000 ex's rpms rising uncontrollably(over 5k)
- Car Wont start After Running
- 1998 Civic Ex cranks but not starting *SOLVED*
- Annoying Mistake on shock/spring install
- Rebuilt d16y8 wont start.. please help
- went to start up the civic....help(911)
- Transmission issue? Maybe?
- Water Jacket nicks?
- 1999 Civic cranks but isn't firing
- Exhaust Gasket Install - See Pic
- IAC & cat problem
- 1997 Honda Civic Dx IAC problems
- Car Wash Trouble Codes
- cut line on cruise control
- stripped wheel cylinder bolts
- Battery discharge problem
- Every week a new problem..(pics)
- sagging brake lines
- Multiple Codes S.O.S. 6th gen civic
- 98 civic speedo issue
- ABS Code 14 "Pressure Switch"
- Blower fan replacement issue
- Replacing IACV what else should I replace?
- Incorrectly wired IAT??
- I need help with my 96 civic
- 97 civic dx engine swap
- ABS Tone Ring
- Transmission issues
- Continues high reving
- Leak '97 Honda Civic CX
- Oil Pans - 97 EX
- Fuel Gauge or Sending unit?
- Civic 98 EXi Automatic Missing
- Common oil leak places? Replaced a few things- Need Help
- Trans issuses
- D16Y7 not starting well, or not at all
- 2009 Civic not cranking
- 00 LX needs a Head Gasket
- losing spark
- B18 not getting fuel?
- Engine rebuilding question
- Think my trans took a dump on highway
- Timing Belt
- 00 LX overheating, added coolant
- Replaced exhaust manifold/cat; weird smell
- Cam Seal question
- 99 si help
- Shorted or Fried Fuel Tank Pressure Sensor
- Coolant leak
- no start
- Brake Work
- 2000 honda civic si computer problem
- 97 HX Coupe Cold Air into Cabin
- Spark plug hole debacle
- 99 honda civic ex idle surging.HELP ME !!
- Can a car be nocturnal? No sun=idles fine
- Positive Camber on Rear Right Wheel
- 2000 Civic LX curb hit, what do I fix?
- 8th Generation Civic Hybrid
- Idle Air Control Valve
- Losing coolant and top front of engine keeps getting sprayed with coolant
- '98 Civic EX Auto Trans Issue
- 2000 Civic shakes at high speed
- 97 civic d16y5 p0107
- 98 Civic - Eating alternators like candy
- Idle Problem: '99 Civic EX
- 1999 Civix LX it is stalling
- Fumoto Oil Valve
- Installing Cruise control in my 98 DX Hatch
- 2000 Honda Civic Knocking Noise Catalytic Converter Exhaust
- Dreaded P0505 FIXED
- 98 CX Not Starting After Tune Up
- Fuel pump retaining nut torque spec- 2004 Civic LX, 4Dr
- Honda Civic DX 97 o2 Sensor Issue's
- Very Good Head Gasket Leak Detection Video
- 2000 honda civic si remote unlock won't work when I lock with the key
- 03 civic ex how do i replace front ball joints?
- Best Axles?
- oil light
- What is this opening?
- Oil Pan Replacement - Check Engine Light
- SRS Light and driver seat
- Confused idle
- REPAIR ANY ACTUATOR - Instructions
- 2000 honda o2 censors
- opinions of my motor falling out.... 2000 ej8
- 2000 Ej8 honda click in the back when i brake
- 01 civic coolent fan problem
- P0700/P0740 Check engine light
- Honda Civic 1999.: Not starting some time or dying during slow driving
- Gas Fume Leak in a 2000 Honda Civic
- 2000 honda civic wont run
- Possible A/C Issue + ? for Ezone
- Wont go past 3500 rpms sometimes
- Cant get the transmission mounted to the engine!
- 98 Hatchback Randomly dies
- Need some help. Don't know much on cars
- #3 cylinder - No Compression
- 98 civic ex wont start after compression test
- 2000 Civic starts only when key is released
- Missing antifreeze
- does my 2000 civic have a trans filter?
- Help!!!
- D16Y7 Engine Knock. It's not the valve's
- Neutral Safety Switch 1999 Civic DX (CANNOT FIND REPLACEMENT PART ANYWHERE)
- IAC repair tutorial
