lazy trasmission
Old Oct 10, 2017
Caseyatbat's Avatar
Caseyatbat is an unknown quantity at this point
lazy trasmission
I have a '99 EX 1.6L with the automatic transmission. It seems not eager to shift gears. It takes longer than it should to make the shift. This is more noticeable when cold. When it warms up it does better almost getting good enough to not be noticeable. There are no flashing lights or other bad indicators. Just a reluctance to shift. It downshifts well.
Old Oct 10, 2017
Wankenstein's Avatar
Re: lazy trasmission
Sounds like slippage. Start with a 3x3 ATF drain and fill. Also clean the shift solenoid screen.
Old Oct 10, 2017
Caseyatbat's Avatar
Thanks for the info. Slippage? That sounds like it isn't fully in gear and the motor races. And what is 3x3 ATF? I mean I know what ATF is but 3x3?
Old Oct 10, 2017
If the engine runs poorly or lacks power for any reason, that can cause the trans to shift late.
Is there a cable leading from the throttle body to the transmission? Could be misadjusted.
Old Oct 10, 2017
Caseyatbat's Avatar
I have no idea about such a cable. I had assumed the linkage was vacuum or electrical. The engine runs well. There is a lag at times but then it picks right up.
Old Oct 11, 2017
3x3 atf (applies to any make/model): https://www.google.com/search?source....0.12yxljD2K0g
Slipping: http://www.autos.com/car-maintenance...-how-to-fix-it
Slipping Vid:
