Rack & Pinion help!
Old Jul 30, 2017
Super Soaker's Avatar
Super Soaker is an unknown quantity at this point
Rack & Pinion help!
Hey so I own a 1999 Honda Civic Si ( 2 Door Coupe ) 1.6L SOHC VTec Automatic Transmission, The Rack & Pinion needs to be replaced and I was wondering if I could use a Rack & Pinion from a Manual Transmission as Automatics are not as common does the Rack & Pinion have to come from another Auto Transmission 99 Civic Si? Or is it possible to take one from a Manual please lend a guy a hand and let me know thanks
Old Jul 30, 2017
Re: Rack & Pinion help!
I didn't see where transmission type makes a difference?
You're in Canada....I looked up a rack in http://torontohondaparts.com
and found the same part number power steering rack was used in coupes, hatchback and sedans as well, so you should be able to locate a suitable replacement easily.
SI-R used a different part number.
Any auto recycler should be able to look up your parts in their interchange manuals and see what years/trims will work with your car.
If you are DIY then look up your possible donor car in the catalog and compare part numbers to your car.
Old Jul 30, 2017
Thanks for the info this should definitely help
