98 honda civic wont start
Old Apr 3, 2017
Richlgato's Avatar
Richlgato is an unknown quantity at this point
Driving down the block car lost powe let go off gas pulled over now wont turn over d16y8
Old Apr 3, 2017
Re: 98 honda civic wont start
Got oil?
Got spark?
Got compression?
Got fuel/fuel injection?
Old Apr 6, 2017
Richlgato's Avatar
Originally Posted by ezone
Got oil?
Got spark?
Got compression?
Has spark fuel injection good change starter now just trys to start but sounds as if a pulley was locked
Old Apr 6, 2017
Wankenstein's Avatar
Test main relay: https://www.thoughtco.com/how-to-tes...n-relay-281325
Did you get the battery tested?
Test ICM and coil: http://easyautodiagnostics.com/honda...system-tests-1 (same test as 1.6L)
Old Apr 6, 2017
Um, as in it cranks unusually slow, or not at all?
Did the starter crap out on top of everything else?
Is the engine locked up? (spin the crank by hand or with tools)
Is an accessory pulley locked up? See if the adjuster pulley for the AC belt locked up, or if the AC compressor pulley locked up (if so, just remove the belt and see if that allows it to rotate).
Old Apr 7, 2017
Richlgato's Avatar
It is turning on now! But now i have a knocking noise not sure what it is now gotta plug and play with it now!!!!
Rubberchickentm
May 28, 2019 07:20 PM
dkocian
Jun 24, 2016 07:46 AM
carlaupl
Jun 11, 2016 08:57 PM
jeffmensch
May 28, 2016 07:42 AM
