#3 cylinder - No Compression
Old Oct 7, 2016
Josh 1973's Avatar
Josh 1973 is an unknown quantity at this point
2000 Civic VP. Was idling REALLY rough, like shaking. I had the plugs and wires etc etc changed but they told me the #3 cylinder has no compression.
That is way more money than I'm willing to put into a 16 year old car.
My question is, is this a car killer? How long does it have?
Old Oct 7, 2016
Wankenstein's Avatar
Re: #3 cylinder - No Compression
Did they do a dry and wet compression test?
A leakdown test?
Either:
1) Compression ring issue
2) Valve(s) leaking
3) Head gasket
Has it been losing coolant or overheating?
Old Oct 10, 2016
Josh 1973's Avatar
A leakdown test?
Either:
2) Valve(s) leaking
3) Head gasket
I don't know what kind of test it was. When they realized it was a valve problem they told me to take it somewhere else. The CEL check showed all 4 cylinders were misfiring. After I changed the plugs, wires, and cap & rotor I checked again and only cylinders 3 and 4 were misfiring.
No leaking or overheating at all. When I hit the gas it evens right out and drives great. It's only while I'm stopped in drive. Putting in park stops most of the shaking.
The car has also had a big evap leak for a while that i've been ignoring.
Old Oct 10, 2016
mikey1's Avatar
what was their suggestion on how to remedy this issue?
Old Oct 10, 2016
Valves can leak compression if they aren't sealing properly. If that's the case the cylinder head will need to be pulled and either a valve lapp (less expensive) or 3-angle valve job performed at a machine shop. The cylinder head will be cleaned and inspected for cracks and warpage. Good time to install new valve stem seals too. A new head gasket, intake manifold gasket, and possibly a few other gaskets may be needed. Depending on the machanis and machine shop used could cost between $700-$1000
Weather it's worth repairing is up to you.
Valve lapp vid:
Old Oct 10, 2016
Josh 1973's Avatar
Valve lapp vid:
https://www.youtube.com/watch?v=7GEmuQa3dPY
Yeah, the guy I had look at it said to take it to a machine shop.
I only paid $500 for the car in the first place. I just want to know if ignoring the problem will eventually kill the car and if so, how long it has left.
Old Oct 11, 2016
mac25's Avatar
Dr Krieger of Modification
double check the ignition wires on 3 and 4 since those ones are still misfiring.
If you can get 4 smooth half the battle will be won.
Secondly you could try disconnecting the third cylinder injector harness plug and pull the spark plug (this will remove what compression is left and spark). This would stop that cylinder from misfiring and increase engine balance. (it will still through a misfire code, but really it will be a no fire).
You can do this on both cylinders as well. Obviously the fewer cylinders the fewer HP.
How to:
2 cylinders
3 cylinders
Hunter Freas
Mar 27, 2016 11:07 AM
EdGasket
Mar 7, 2016 05:35 PM
adamfoetou
Mar 6, 2016 04:40 AM
Aliciawb
Feb 23, 2016 06:19 PM
BeefMan
Nov 25, 2001 10:38 PM
