Front Suspension : What Needs To Be Replaced?
Old Jul 21, 2017
lindylex's Avatar
lindylex is an unknown quantity at this point
I noticed some vibration in my steering wheel. This is what I saw. Can someone tell me the names of the parts I need to replace?
It looks like two parts where the tie rod connects the boot. The part below it has no bolt on it anymore.
Old Jul 21, 2017
Re: Front Suspension : What Needs To Be Replaced?
the boot you will need to take to a shop - align afterwards, no easy way to do it without aligning it. better have it done at the same time as the sway bar endlink mentioned below
the other part, you will need a new sway bar endlink
change both anyway - easy to do
Old Jul 21, 2017
lindylex's Avatar
That was the easiest repair I have ever done.
I am going to do the boot that attaches the sway bar to the body of the car. I might have to remove the sway bar end link again. Thanks for the help.
