01 civic coolent fan problem
Rep Power: 0 01 civic coolent fan problem
Hey everyone I have a 01 honda civic lx and It has been overheating, so I found out that my fans won't come on unless I turn the ac on, so I went under the hood in the fuse an relay box an found the 20 amp fuse took it out an the ac fan still ran but the coolent one did not, so I put it back in an it came on with the ac fan.... I turned the ac off an found the relay under the hood and swapped it with the horn relay cause it had the same numbers an the fans are working like there supposed to now, but my question is how can I check an make sure the fans are workin or what the problem might be or have been....
Re: 01 civic coolent fan problem
If both fans ran when the AC was on that verified they will work if the PCM tells them to.
The only thing left for fans is to verify the temperature switch (in thermostat housing) works correctly and the fans will run when that sensors connector is jumped.
Low coolant in the radiator causing overheat? Reservoir overfills and/or overflows?
Replace the head gasket....check head for warpage.
Rep Power: 0 Re: 01 civic coolent fan problem
Yea it was pushing coolent into the overflow, but oil looked good an it passed head gasket tests, so I replaced the thermostat and then filled it up with coolent and the car got to operating temperature but the fans never kicked on.... I ran the car a good 10 mins burping the system and they never came on, then I started messing with the fuse an relay
Head gasket is blown. That failure may pass every check most people can think of.
There is only one test that has been dead reliable for me on this engine. A head gasket could fail in any of a dozen different ways but it consistently is just one particular way on this engine . It fools almost everyone who stumbles in here and posts that it can't possibly be a head gasket because it didn't bla bla bla.
10 minutes may not be long enough to get the fan to come on, depending on conditions. If there is any breeze at all or if it is relatively cool out it may stay cooled enough to not need to run the fans.
