IAC repair tutorial
Old Sep 16, 2016
xxbgxx's Avatar
xxbgxx is an unknown quantity at this point
IAC repair tutorial
so if you have a rough idle or idle ralated issues its worth looking at the IAC or simple the idle valve .
the good thing is the idle valve the civic uses is serviceable so unless the coil is burned the problem is usually rust or debris .
the MAP and TPS can be cleaned in a similar way.
By checking the resistance you can make sure the TPS , MAP and Idle valve coil are working properly.
what is required .
1-wire brush
2-kitchen degreaser
3-ultrasonic cleaner ( a small one cost around 30$)
4-ultrasonic cleaning fluid i prefer ASNU brand or if not available water and a very small amount Laundry Detergent for non electronic parts.
5-gasket silicone
if your idle valve looks this bad it means the whole throttle body needs maintenance but that's anther write up.
1-you remove the idle valve from the throttle by removing the 4 bolts .
2-inspect for any physical damage any cracks or broken parts inside means that you need to replace it.
3-clean the whole thing with water and kitchen degreaser
4-using a wire brush clean as much as you can. for hard to reach areas i use a small electrical wire brush.
5-the ultrasonic cleaner will clean where you cant. keep the parts and the bolts for 15 to 20 minute in the ultrasonic cleaner.
6-let everything to dry and apply a small amount of silicone where needed.
Old Sep 16, 2016
Dooner's Avatar
GOT SAND?
Dooner is an unknown quantity at this point
Re: IAC repair tutorial
Good DIY, but you might want to post pictures, or describe where the IACV is located for those that don't know.
Old Sep 17, 2016
xxbgxx's Avatar
today i will do the throttle so i will post more pictures.
Old Sep 29, 2016
xxbgxx's Avatar
well there is a thing i forget to mention is testing the IAC .
its a 3 pin coil the center pin is positive and the other 2 negative one for opening the valve the other for closing .
if its stuck try to rotate it until its loosen again.
to rotate it you need to remove the electrical coil and rotate the small magnet
Also apply a little amount of silicone grease at the spring and where the pin meets the magnet to keep the valve moving as free as possible.
i dont see why the need to replace unless its broken since its a a very basic low tech device.
redman24
Aug 10, 2016 08:11 AM
divinmule
May 5, 2016 08:24 PM
Drix
ECU Fried
Mar 18, 2016 05:08 PM
VictorWilliams
Mar 1, 2016 11:54 PM
ilgnay
Apr 26, 2010 11:53 PM
