- Car has no power to any electrical
- 1996 honda civic had engine swap what header do I use?
- Worth it to replace Timing Belt at 180,000 miles?
- No power at disributor Civic 1,4I -97
- 99 Civic wont start
- Oil Leak Near Crank Pulley
- 98 Civic LX post-overheat issues
- 1998 civic lx valve tap when its cold
- 1997 Civic Instrument lights inoperative
- 1998 Honda Civic 1.6 low idle and vibration when trannie is engaged
- Broken passenger turning signal 2000 honda civic coupe ex
- i need to know what this piece is called. help!!
- Brand newbie with surging idle 97 Civic
- CV boots torn
- Ok this ones tricky. 1998 Civic EX overheating problem.
- just cranks
- Worth repairing? Or cut and run?
- Another over heating question / head gasket
- I have 99 civic EX and I have a problem.
- problems with my free civic, need help!
- Can Anyone help !?
- 1997 Honda Civic Acceleration Problem
- Gas Mileage Problem, Leak or something else?
- LSVtec Valve Cover Gasket Blowing & Gushing Out Oil
- 2004 honda civic hx automatic transmission swap
- head gasket blown but perfect compression?
- 97 d16y8 timing issue
- Oil Change?????
- Coolant inlet gasket??
- 1000 dollar car.
- "Double engagement on felt going into drive"
- 2000 ex running problem
- 1997 Civic DX Radiator Issue
- 98 Civic EX Gas smell
- Old Civic whines at high speeds - On a Road Trip - Help very much appreciated
- 2000 Civic CX is suffering from... Narcolepsy?
- new intake loss of power
- 1998 civic lx randomly dying
- 97 ex d16y8 car misfiring
- Power Steering Pump
- Electrical Problem
- Urgent CV Shaft Match Problem!
- 1998 Civic Lx coolant overflow problem?
- OBD-II Code 1336
- o2 sensor problemmm
- Thinking about buying a different honda, would like some advice.
- How to remove the entire rear interior?
- 1998 honda civic d16y7 automatic dx performance issue
- Heating up when going up hills
- Header/downpipe help!
- '96 Civic Major Engine Problem
- Spark Knock
- 2000 civic Si Fuel Pump Not Working
- 99 DX could not start after replacing ICAV
- Flashing Check Engine Light? 98 CIVIC LX
- My E-brake doesn't work
- Civic 98 Fender
- Throttle cut off, on ,off, car coasted to a stop, rumbled, died, won't start now.
- Where to start?
- Spoiler removal
- Adjustable Lower Control Arm
- No heat in 99 Civic
- Speedometer not working
- 1998 civic sedan water moving noise in interior
- smoking belts... eek!
- Needing parts
- Code p0302
- 1999 EX Lock Questions
- 1999 Civic SI overflow filling up.
- 2000 civic dx ecu
- Idle issues
- Help in stuck in Yellowknife!
- Knocking
- Front left motor mount
- sputtering question
- TDC Sensor???
- Input shaft bearing issue?
- Trying to understand my set up!? 99' hatch w/d16y8
- 96 civic ex w/ idle and starting issues
- 1998 Honda Civic DX Hatchback automatic pulls before going into second gear?
- Coolant disappearing
- 2000 civic ex auto wont start
- 98 Civic LX Misfire
- 99 Civic No Shift
- Honda civic 1999 idle issues
- Front grinding popping Noise from wheels
- Wanted to post up a reference to a Wiki with how to's, manuals for the Civic
- Rear bumper sag fix???
- 1999 Acura CL 1259 Code
- 97 dx d19y7 Electrical Load Sensor replacement help...
- How to get fuel rail off D16Y7?
- Need rear struts, compatibility question
- No start, Engine flooding?!?!
- 1998 HX CVT transmision codes
- Just a girl that dunno lol
- 97 Civic EX having *Terrible* sputter problem.. please help!
- please help! new motor mounts, motor sitting side ways
- A/C controls working backword, ????
- 99 LX CEL problem
- 97 ex 5spd not running
- man!!!!!! ripped off
- first time owner of 98 civic ex 1.6l vtech
- Noisy valvetrain?
- throwing code p1362, Ohms good, no short, WTF! Please read and help!
- 2000 Civic SE, Corrosion & Replacement issue
- 1999 Civic GX Tranny
- 98 Honda Civic HX sputters when accelerating. Feels bogged down and lacking power.
- Eating Antifreeze ...
- I'm smart, but I know little about cars.
- New Exhaust, No Power, Low Idle, Wtf
- 2000 Honda Civic Ex Sputtering, Jerking,Randon RPM Increase
- Not Starting P0335, P0113, P1509
- How do I know which D series engine I have?
- ~*99 1.6L Civic Problem Starting. Need info please!*~
- civic idle issue
- CV boot punctured
- Bolt Broken off into Engine Block
- new help new to honda
- Injectors stopped out of no where
- starter grinding
- transmission break in?
- 99 civic wont start. Has spark, no codes, timing good, WTF! help!
- Transmission: Resistance Shifting
- Alignment after shock replacement?
- Loud Squeal, Car Dies. A/C Compressor?? HELP!
- Radiator cap question
- replace upper tie bar
- Blinking Battery light - stops when headlights are on
- If "floored", won't go passed 50 or 60 mph.
- Advice
- 96 Civic Hatch DX, Braking/Reversing problem
- Odd Transmission Sounds
- 2000 Civic LX Clutch Replacement Cost
- i need an engine
- Engine Popping 3000 RPM
- 97 Civic LX Overheat
- What engine do I need?
- Honda bogs when I push excelerator
- Strange Intermittent Power Loss
- Strange exhaust smell in cabin
- bad ecm or tp sensor?
- '00 Civic- Need help installing a RPM Tach
- Random stalling and shifting at high rpms
- Need help 96 civic right rear lock up
- 99 civic won't start when cold outside
- civic won't start when cold outside
- Shift Shaft Seal- Manual Transmission
- Car Jerking
- D16Y7, Replaced cylinder head, car sounds like a boat *UPDATED*
- AC Gas coming into cabin?
- 97 honda civic hatch header question
- d16y8 help! is there a way to repair this?
- Disconnecting parts from head
- Strange overheating
- 2000 si really rough shakey idle
- Throttle Position Sensor
- Engine Type
- (TDC) replaced no fix car
- Honda Civic LX Transmission Issue
- overheating
- Barely High CO Emissions Reading
- B20vtec civic smoking problem. please help
- 98 dx hesitation/gentle bucking, lights dim, mpg decline?
- Loss of power and gas eater after tranny job
- 98 Civic fluctuating idle problem
- 98 Civic erratic idle when warmed up
- AC/heat fan only works on 3 and 4
- '96 Civic Coupe auto tranny problem. HELP!
- 98 clutch/trans problem
- Need help for Front LCA
- 99 Civic LX Transmission Dilema????
- AC Performance? Poll
- engine temp increasing with hard acceleration
- Having Issues with Magnaflow!!
- '99 Civic EX Transmission
- Dreaded P0420 Code with new Magnaflow Cat. Converter!
- cooling system
- battery dies over night
- Trans numbers?!?!
- Just to make sure about timing belt!
- Rough idle at cold start
- No idea what's wrong :(
- rpms surging
- Car not going into first gear all the time
- 98' Honda civic wont start
- helpppppppp
- Fuse keeps blowing...what do I do?
- 98 Civic EX Oil Seal Identification
- Code P1457 2000 Civic
- 2000 civic. check engine light on but no code
- Dead 2000 Civic EX
- Engine/Motor Mounts
- Weird Noice when shifting
- '98 Civic DX surging IAC issue, P0505, P0420 codes
- 1992 honda civic cx misfire
- Power Window Help
- 97 civic not starting
- Fixing a loose bumper
- Temperature problem
- wiring harness issue.. i think..
- Hood Latch
- Tail Light Assembly
- Crankshaft position sensor
- 97 civic, Random hesitation, TPS already replaced
- Whistling sound when changing A/C setting
- 96 civic with check engine, abs, & srs lights on.
- will universal cat fix my check engine light
- 98 Civic LX Hesitation
- 99 Civic No Acceleration
- Trans not engaging to go into gear
- Steering rack seal kit?
- '96 not starting with key.
- Broken glass put down fuel filler/tank
- A/C compressor fan and compressor not engaging (No dash light)
- 97 Civic LX Messed up Cylinder head..Please help!
- 2000 Civic EX transmission and CEL issues
- 2000 Civic LX Sedan-Can't Get Door Open
- 2000 LX - Exhaust Manifold replacement without the cat
- A/C clutch won't engage
- HELP!!! No Start and completely stumped...
- 1998 Civic EX Overheating, New Purchase Advice
- Hood latch issues
- 98 civic ex not firing
- Differential wont come out?
- Need help really bad. Clutch problems now wont start
- Rebuilt head - Still burning oil
- Overheating, maybe water pump?
- Weird noise coming from wheel area
- Car Dies Please Help
- 98 Civic window regulator question - crank/manual windows
- 98 Civic 4 Door Automatic Sudden Power Loss During Cold/Initial Start
- 1996 Civic DX Air Conditioning question
- 2000 Civic EX died when driving through a puddle.
- 1996 civic a/c isnt bloeing cold???
- model number on o2 sensor doesn't match box
- driver's power lock won't close all the way
- 97 Honda Civic LX wont stay in gear
- Transmission slips when hot
- 97 EX Coupe Pass Pwr Window Dead New Motor
- 1997 LX airbox swap to dx,ex,
- Hood latch stuck open
- 97 Civic lx Wont Start.... Coil Pack maybe?
- Windshield Wiper
- brake conversion
- 97 Hatchback - open hatch with no key
- 2002 Honda Civic code P0730
- 1989 Honda Civic Fuel Filter
- Weird problem with A/C compressor
- Idle keeps Alternating from High RPM to Low RPM
