Gas Mileage Problem, Leak or something else?
Old Nov 3, 2012
2oo3EX's Avatar
2oo3EX is an unknown quantity at this point
Hi i have a 1996 cx and it is sucking down the gas. I have looked everywheres on the fuel system when it was running and not running and can't find any leaks. The gas only goes down when it is running when it is sitting it will keep its fuel. It has also fouled a set of plugs and when i put my hand to the exhaust i can feel unburnt fuel so it leads me to beleive that it is flooding the cylinder. I was wondering if anyone knew or has had the problem with their civic and knows a fix?
Old Nov 3, 2012
Re: Gas Mileage Problem, Leak or something else?
No, you can't.
Is the Check Engine Light on?
Does the car run poorly?
Fix that.
Old Nov 3, 2012
Kennykid2002's Avatar
Kenny the Ricer
It prolly has a faulty gauge, or something's wrong with the engine.
You can't feel "Unburnt fuel"...
H2O and CO2is the only byproduct of a combustion engine.
So either, you're feeling hot water coming out, which is normal.
Or you're getting black spray coming out of the exhaust, which isn't normal, meaning you're engine is burning oil.
Old Nov 3, 2012
2oo3EX's Avatar
well all i know is the exhaust is real wet and i think its the oil because the exhaust smoke is white with a tint of blue.I dont think my check engine lights on but it could of burnt out or not be connected because the car doesnt idle right either and burns all that fuel and has a brake leak and none of my idiot lights turn on
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
Thees1
Apr 14, 2015 08:23 AM
plastikman
Bolt-on Engine Performance
Dec 13, 2001 03:18 PM
MY01HX
Nov 12, 2001 04:25 PM
