'99 Civic EX Transmission
Old Aug 7, 2012
mjme001's Avatar
mjme001 is an unknown quantity at this point
Hi all, New to the forums and new to Civic.
I bought a '99 Civic, 47k, great condition (Or so I thought) after about 2 weeks I've noticed it shifts a little rough. It's only in some cases. When I'm getting on the freeway and give it plenty of RPM it shift pretty much normal, however, when I'm in traffic at low speeds it tends to "kick" or jerk into 2nd and third. It's not a real bad jerk, and there is no noise but I can feel the hesitation and then like "thunk" into gear. Again when I give it plenty of RPM it doesn't do this. Also when going down a hill not accelerating it jerks into second.
I've check the fluid and it's good. My next step was to do a flush but I wanted to ping here to see if it's a sign of bigger woes. I don't know too much about cars (my knowledge is nominal) so thought I'd ask you gear-heads. I'm sure I've left out info so let me know if you need more. if anyone knows why the tranny would be a little spotty please let me know.
I have searched on here but haven't really found anything matching my exact isssue. Thanks in advance.
Old Aug 8, 2012
asianboy781's Avatar
asianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the roughasianboy781 is a jewel in the rough
Re: '99 Civic EX Transmission
do a flush and see it from there but when the transmission starting to jerk into the next gear its a sign of hitting the hell hole, honda is known for having glass transmission and worse on there automatics. my friend 00 honda civic lx does the same jerk and his is at 150k miles and still running. and if the jerk gets worse and tranny starting to slip then you need to rebuild it or find a used one off the scrap yard
Old Aug 11, 2012
mjme001's Avatar
Funny thing...I took it to the Transmission shop and the guy drove it around for about 10 minutes and came back told me " I don't feel any problems with it." and "Just have it serviced." I was like WOW you don't feel the crappy shift???......Apparently not, and this guy comes highly recommended He seemed like a square dude but I was floored when he told me, basically, "yea nothing's wrong with it. Have it serviced."
Old Aug 11, 2012
palsana's Avatar
palsana is an unknown quantity at this point
are you saying a 99 civic with only 47k mi? is that right? really low miles.
At that miles i dont see you flushing the transFluid!!!! just change it.
Im on 03 civic with 180k mi doing my first/second ever transfluid change. Have exactly the symptoms you describe, and i will run it down until the TRANNY DIES on me, and it will be the end of THE CIVIC AS I KNOW IT...i am hoping to get lucky and be able to keep it/drive it until atleast 200,000 mi + and i will call it a success. (under the circumstances you describe).
Please really dont flush it, add additives if only necessary!!!!!!!!!!!!!
Old Aug 13, 2012
mjme001's Avatar
Yea man....47k, was a pretty good deeal, it was taken care of apparently. I think an old lady owned it before me, but yeah same here I will probably just run her 'til she breaks then go from there hehehe I will try and add some fluid see if that works but not sure what else to do...
Old Sep 11, 2012
bill breeden's Avatar
bill breeden is an unknown quantity at this point
I have a 97 civic and am having the same problems. Is there a chance that a flush of the torque converter will fix it?
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
C6GrandSport
Apr 25, 2015 09:41 PM
Rinzlor
Apr 24, 2015 10:33 AM
Richkid23
Apr 19, 2015 12:53 PM
