No power at disributor Civic 1,4I -97
Old Nov 25, 2012
Olle's Avatar
Olle is an unknown quantity at this point
Hi,
Im meshuring 0 volts at the distributor with the ignition on.
What might be the problem?
Regards Olle
Old Nov 26, 2012
98Honda4banger's Avatar
98Honda4banger is an unknown quantity at this point
Re: No power at disributor Civic 1,4I -97
did you recently tinker with any of the electrical components? Obviously something is going on with the circuit running to the distributer.
Old Nov 26, 2012
FrankHondatech's Avatar
6th Gen Honda-Tech
FrankHondatech is an unknown quantity at this point
Originally Posted by Olle
Hi,
Regards Olle
1st : Check all your fuse.
Unplug the Distributor and check the resistance at the connector to the battery ground. If you have over 2.5ohm Check the cable it may be bad somewhere if you get Ol then its cut somewhere.
1slowcivic
Aug 11, 2010 08:06 PM
Nameless
Jul 18, 2004 10:53 PM
DizWikedCivic
Jan 25, 2004 08:47 PM
