new intake loss of power
Old Oct 26, 2012
Honda12345's Avatar
Honda12345 is an unknown quantity at this point
Question new intake loss of power
i got a honda hx with a b16a2 dohc vtec in it it recently had a horrible intake on it, it had a long ram with a specter filter on it. The ram and the filter where old as dirt and had rust on it so i replaced it along with the metal bracket peice that goes with the intake to the manifold and so forth. Anyway it has gone downhill so bad i have lossed so much power and the gas is going down so bad its not funny ive talked to a couple people and their stumped too!! The old filter that was messed up put out more power than the new short ram please help if it makes the difference its a 97 motor!!! I was also throwing an 02 sensor code and a couple others but dont think it would effect it that bad!! I could be wrong im no machanic!! Also the gears have changed 55mph would be at around 4 grand in 5th now its like MAAYBE 3 grand (rpm) its like this from 3rd up!
Old Oct 27, 2012
Re: new intake loss of power
intake should not affect much unless there is an air leak or a sensor is not installed properly.
Old Oct 27, 2012
Honda12345's Avatar
I wouldnt have figured it would either but it didnt start until i swapped em out i know the o2 sensor going into the intake is hooked up good but theres another sensor thats not hooked up but it has no spot so idk any ideas of what it could be?!
Old Oct 27, 2012
could be the MAF (mass air flow) sensor? that would noticably affect how the car drives.
Old Oct 27, 2012
nsxvtec's Avatar
nsxvtec will become famous soon enough
Your O2 sensors are in the exhaust not the intake. You mean the IAT (Intake Air Temperature) sensor. Have your engine checked. A Leak-down and a Compression test should give some idea as to the condition of the motor. Also check the IAC (Intake Air Control) Valve or EGR (Exhaust Gas Recirculation) Valve. 97 Civics do not have a MAF (Mass Airflow Sensor).
Old Oct 27, 2012
Honda12345's Avatar
Ok thanks ill do that i really apprecieate the ideas!!! This had me so agrivated it wasnt funny!!!!
Misfit2613
Jul 30, 2015 09:49 AM
1khilari
Jul 9, 2015 08:12 PM
Ccoop87
Jul 9, 2015 03:26 PM
hayden55
Jul 8, 2015 11:38 PM
7thgensurvivor
Jul 5, 2015 12:17 PM
