2000 civic Si Fuel Pump Not Working
Old Oct 13, 2012
SlammedEM1's Avatar
SlammedEM1 is an unknown quantity at this point
ok my car has been having some starting issues, last night i thought it may be the coil in the distributor so i replaced it. i cranked the car it ran for about 30 seconds then shut off. so today i tried putting the old coil back in and noticed that when i turn the key to the ON position i dont hear the fuel pump and the CEL light doesnt come on for 3 seconds then go off like it should. So here is everything i have done ive checked the 15amp fuse under the dash its good, i changed the main relay still nothing but what is odd is that the fuse in my engine fuse box the 15amp keeps blowing i even put a 20 amp in it and it still blew it but still no fuel pump. ive looked everywhere and done my research and i havent found a valid answer. help please.
Old Oct 14, 2012
SlammedEM1's Avatar
Re: 2000 civic Si Fuel Pump Not Working
ok so i got the fuel pump working and ecu is now getting power. my ecu wires where in a bind. i am still having a problem with it wanting to start though. sometimes it will start right away then it wont want to fire up at all and when it trys it makes some god aweful growling noise from the intake then blue smoke comes from my intake. ANY INPUT WILL HELP
Old Oct 14, 2012
i dont hear the fuel pump and the CEL light doesnt come on for 3 seconds.....i changed the main relay
I would be testing the item(s) that controls these things.
No clue there from me.
Old Oct 14, 2012
SlammedEM1's Avatar
[quote=ezone;4620789]I would be testing the item(s) that controls these things.
i got it running but its still having a starting problem the ecu is getting power and the fuel pump is priming. im stumped.
Old Oct 14, 2012
But you said the CEL doesn't come on right away, you have to wait until it comes on and THEN it will start?
And the fuel pump also doesn't run until the CEL comes on too?
Or did I not understand that...?
The PCM operates both the CEL and the main relay.
Tried wiggling the ignition key (switch) to see what happens with the lights?
Does this fuse have anything to do with it not starting?
What is this fuse for?
Old Oct 14, 2012
SlammedEM1's Avatar
no everything is working properly dismiss the first post im dealing with the second one now. its running im dealing with a miss fire/hesitaion issue.
Old Oct 15, 2012
Oh, ok. Sorry.
Um, got codes from the computer?
Basic ignition system checks for misfire? (Cap, rotor, wires, plugs.)
Old Oct 15, 2012
SlammedEM1's Avatar
no codes, and ive checked all that i even replaced the distributor coil. heres everything ive done, checked timing, checked plugs, replaced spark plug wires, replaced cap&rotor.
Old Oct 15, 2012
How about timing and fuel pressure?
Old Oct 15, 2012
SlammedEM1's Avatar
both good, i think it may be the cps ( crank position sensor ) i just remembered my hatch had a similar problem to this.
CarStuff
Dec 6, 2020 12:52 PM
rcolosi
Apr 29, 2015 07:48 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
