No heat in 99 Civic
No heat in 99 Civic
I have a 99 Civic HX and the heat is not working in it. It blows air out but it doesn't get hot or even change temperature. It is full of coolant, I flushed the heater core, and changed the thermostat but it still doesn't get hot. I noticed that the heater contol cable that opens and closes the heater valve on the firewall doesn't move when you adjust the heat from hot to cold. I took the cable off and adjusted to the valve manually making it fully open and fully close but the air still didn't change temperature. Now I am all out of ideas so if anyone could help I would really appreciate it. Thanks.
Re: No heat in 99 Civic
You said the cable didn't move.....
That might mean the temperature door (air mix) actuator isn't moving either. It's attached to the bottom of the heater case, toward the passengers side...
Has linkages, cable attaches there too.......
You might try a push/pull on the linkages while twisting the temp ****, see if a nudge will get it started moving again.....
There are electrical tests you can do for it, you need some good service manual info for it.
The heater control panel can do some self-diagnostic stuff, there is a "button dance" to enable the tests. You would need a good service manual.
HTH
HTH
I couldn't get the cable that controls the heater valve to move. Is that the cable you are talking about? Do you know what the "button dance" is for the self diagnostic tests?
A library would be a good place to start looking for service info. Many have access to Alldata or Mitchell info systems these days.
That's what I was calling the heater valve. When I flushed the heater core I sprayed water through it and it came out the other tube, so it must be open. I will take it off tomorrow and make sure though.
FYI: Today I looked at an 03 Acura MDX (same as a Honda pilot) with the water valve bad, the arm that the cable attached to wasn't really connected to the valve anymore, the shaft inside it had rotted the plastic apart. The cable and the arm all moved, but it really wasn't operating the valve.
Different problem, same result: No heat.
If your water valve had water flow through it, that means it is open and the core should be getting hot antifreeze flow properly. Your problem should be that the (air mix) door inside the heater housing isn't being moved from "cool" to the "hot" position by the servo (actuator).
HTH
HTH
mikemc422
Aug 9, 2018 05:41 PM
cooldan1
Apr 23, 2015 10:49 AM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
