Oil Pan Replacement - Check Engine Light
I just replaced the oil pan and passenger side axle on my 1999 Civic EX 2DR.
I did have to disconnect the exhaust at the A-pipe to get to the oil pan.
As soon as I started the car up for the first time after the repairs, the check engine light came on (in 50,000 miles that I have had the car, I have never had an error code until now). My gut tells me that I messed up the wires going to my secondary oxygen sensor (as I didn't support the exhaust that well).
I will be checking the actual codes later this week, but I was wondering if anyone else has had similar issues before.
Thanks
Thanks
Re: Oil Pan Replacement - Check Engine Light
Ya, if your work caused sensor wiring to be pulled stressed or yanked, you could have caused it.
Double check, maybe it can be fixed somewhat cheaply. Maybe not.
I pulled the code today. It is "P0135 - O2 sensor heater circuit, bank 1 sensor 1". It seems like this is the primary sensor, however, the only sensor/wiring that would have been stressed would have been the secondary sensor under the car. Any ideas?
Get under there and take a look!
Might want to disconnect both the primary and secondary o2 harness connections and spray both male and female ends with electronic cleaner/lube then reconnect. Make sure to to do an ECU relearn afterwards.
I did this 4 months ago with a speed sensor and connection and haven't had an issue or CEL light since.
