Appropriate engine temperature
Old Apr 30, 2017
ZachCivic's Avatar
ZachCivic is an unknown quantity at this point
Runs at 195 consistent. Just saw it up at 205 and stay there after driving up a long gravel hill. How's that sound?
Old Apr 30, 2017
Re: Appropriate engine temperature
Not out of line for an engine under a load IMO.
Did it drop back down after getting past the hill and resume flat ground travels?
Is the radiator completely full and radiator fan runs when it should?
Old Apr 30, 2017
ZachCivic's Avatar
Well the hill was the end of the drive and I let it sit for about a minute and it dropped to 203 then came back up. fan was on, running well.
car makes a UFO glug glug glug sound, doesn't sound like the engine so I'm wondering if it's air in the coolant. I bled it for like 45 on a flat area, thinking about an incline but those funnels are expensiveeeee :/
Old Apr 30, 2017
Top of a water bottle works well in a pinch, provided you have something to cut the top off with. Alternatively, good aim has done me well for pouring coolant
Old Apr 30, 2017
6th gens can have head gasket problems the same as 7th gens, slowly pushes coolant into the reservoir and hard to figure out, will pass the usual checks most people can think of.
Old May 1, 2017
ZachCivic's Avatar
Milled the head and replaced the gasket recently, I really hope not
