PDA
View Full Version : Fuel, Oil, Cleaners & Other Maintenance
Pages : 1 2 [3] 4 5
  1. My car leaks a gallon of oil per week. What's the cause?
  2. Check Engine light is on.... TPSensor changed 02 civic...help needed
  3. Car occasionally cranking and not starting
  4. 96 honda civic. need help with diagnosing 02 sensor malfunction
  5. Rough Idle after maintenance
  6. Check Engine light on, autozone says transmission
  7. Horrible gas mileage
  8. full body paint
  9. Replace O2 sensor, now engine hesitates
  10. Odometer?!?!?!
  11. Oil pan gasket etc. replacement on 2001 Civic
  12. two way valve?
  13. Does a 2002 Civic have a check engine light?
  14. Lithium White Grease 4 exterior weatherstrip?
  15. Timing Belt - How much?
  16. possible bad fuel pump/filter?
  17. Honda 07 civic ex Oil light hits 0% then goes negative? how many miles i have left?
  18. Will Doing An Oil Change Help???
  19. Ac
  20. Seafoam:)
  21. Gas Mileage Decrease?
  22. 92 hatch radiator issues???
  23. Check transmission fluid level
  24. 97 LX Transmission Problems - Change or Rebuild/Replace
  25. Intake sensor on cold air?
  26. Honda Oil Question
  27. Fuel filter
  28. Transmission Filter?
  29. D16Y8 Distributor O-Ring
  30. Can I replace valve seals myself? I'm burning oil
  31. Prestone Flush 'N Fill?
  32. 75,000 mile maintenance?
  33. Why is my 1st gear so hard to engage?
  34. Regular maintenance for a heavy city driver
  35. Meguiars Plastx
  36. Cleaning under hood
  37. Faulty Brake Light- 99 Civic EX
  38. Engine cooling fan
  39. Replacing O2 Sensor
  40. Oil Changes & Leasing
  41. Heater not working
  42. 02 civic si airbags
  43. 1998 Civic D16Y Engine Oil Leak
  44. 93 civic dx advice fluid changes
  45. Best dash/glass cleaner
  46. New fuel tank/gas tank for 02 civic?
  47. 2007 Civic LX Transmission Oil Capacity
  48. 2000 civic maintainence
  49. 8th Gen Purge Control Cylinoid Issue
  50. oil light
  51. '97 Civic LX Timing Belt Replacement
  52. 1997 1.4 tornado wont reach top speed
  53. Removing Scratches?
  54. 100,000 mile maintenance
  55. 93' EX fuel pressure??
  56. What Spark Plugs Do You Use?
  57. Gas/fuel Recommendation
  58. What are the best spark plugs for civics?
  59. Valvoline Maxlife Dex/merc
  60. 09 Honda Civic LX Oil Changing
  61. Dealer overfilling my motor oil?
  62. change auto tranny fluid with ramps
  63. O2 Sensor Problem...?
  64. Best fuel for Honda Civic vtec 1998?
  65. timing belt or chain
  66. '96 Civic 1.5 - gearbox oil change
  67. Fuel Gauge Problem?
  68. Top Radiator Pipe Blew off Saturday!
  69. 1982 Civic 1.3 Stalling When Hot
  70. Fuel Injectors (When And How to clean them)
  71. 96 civic Ex - A/C problem
  72. Transmission Fluid
  73. I have a leak in one of the pipes
  74. Rust Converter
  75. scratch-X and orbital?
  76. Sohc
  77. car wouldnt start
  78. change cabin filter
  79. PCV Valve?
  80. Question About Battery Changing Procedure
  81. PCV Valve questions
  82. 95 Honda civic EX 1.6 Thermostat Housing
  83. Maintenance @ what millage list
  84. Kendall Motor Oil
  85. Failed o2 sensor at 55k miles ('04 civic)
  86. how often to run engine of not-often-used car?
  87. Emissions malfunction light, then putters sluggishly
  88. changing oil @ 5K
  89. Need help with headlights
  90. Throttle Body Clean up Honda Civic 2001 EX
  91. Automatic transmission fluid buring after only 10,000 miles?
  92. 1993 DX hot weather problem...HELP
  93. Hissing/Grinding Noise
  94. P1456
  95. 2004 honda civic transmission fluid
  96. Help
  97. 2005 Civic Coupe EX: timing belt or chain?
  98. Honda Civic 1995 1.3 starting problems.
  99. Big mistake, Bigger problems, need your help!!!
  100. 2007 Civix EX Oil Change Questions
  101. 2006 Honda Civic EX - white smoke coming from hood
  102. Need some help. Maybe my alternator?
  103. Trunk latch bounces open
  104. Trunk latch bounces open
  105. idleing problems
  106. First Major Problem
  107. Not Quite Overheating, but...
  108. Engine Overheating Mystery
  109. Heat issues in 2001 Civic
  110. Transmission Fluid Service Choice
  111. Clutch Problems????
  112. civic 04 ATF fluid
  113. 94 Civic pouring coolant from underneath engine
  114. '97 DX Stalls, PLS help
  115. 97 civic EGR touble...
  116. rattle in cat
  117. fuel/trunk cable broken. HELP!
  118. engine trouble
  119. 1995 Honda Civic losing oil ?
  120. need suggestion on maintainance of civic 2005 lx
  121. Scheduled maintenance for car driven 2K miles per year?
  122. when should I change timing belt
  123. Need timing belt replaced!!
  124. Fuel Door Issue OMG -.-
  125. Intermediate Service Cost
  126. bummer smog check
  127. D/S headlight keep going in and out
  128. Timing Belt change- is it due?
  129. 60,000 Service for Civic - suggestions
  130. Quarts of Trans Oil ?
  131. Maintenance Minder Codes
  132. 96 Civic Losing oil...but where?
  133. NO fuel! HELP PLEASE!
  134. New to the Forum Need Help with my 2004 Honda Civic Ex Coupe recently purchased
  135. Timing belt at 76K for 2000 civic?
  136. 1993 Civic EX not getting oil to the oil filter
  137. 30,000 mile maintenance on 2006 Honda Civic LX
  138. 8th Gen OEM Radio Swap
  139. what i should change for my car maintence civic lx 02
  140. What is wrong with my engine?
  141. Oil for Trans Fluid?
  142. Oil for Trans Fluid?
  143. Oil for Trans Fluid?
  144. Tranny Fluid Change
  145. Cold start issue
  146. Looking For Lifting Points
  147. rough idle, acting weird.
  148. ventilation - NEED HELP ASP
  149. idle problem
  150. ECU problems??
  151. How To Bring Up Error Codes On a 1997 Civic
  152. Spark plugs
  153. tranny fluid?
  154. do i need a new clutch?
  155. fuel smell in cabin
  156. Transmission Problem
  157. ODOMETER: Flashing negative miles.
  158. 60,000 Miles Maintenance suggestions...
  159. Tranny problem after ATF change
  160. 09 Civic LE.. good car ?
  161. error code p0134
  162. I wanna change my 2000 Civic HX's manual tranny fluid. Few Q's
  163. differential diagnosis on car losing oil
  164. 93 Civic Issues
  165. Scheduled Maintenance and Tires
  166. Bad gas...Misfiring cylinder + Injectors replacements
  167. Transmission Fluid
  168. Oil Filter and the anti-drain back valve
  169. Maintenance Question
  170. Air conditioning
  171. 2001 Civic EX - Wipe Fluids not squirting
  172. Where is all my oil going????
  173. 2004 Civic - Timing Belt or Chain?
  174. 2005 HCH O2 Sensor
  175. Coil vs. Ingiter
  176. Fuel Type
  177. Low Level Windshield Washer Light is ON
  178. is this good oil for my motor
  179. Most Wettest/Glossiest Wax?
  180. Help...Manual transmission fluid change....did I F*** up?
  181. Oil Change => Honda Civic LX 2008
  182. honda civic computer
  183. Replace Fuel Filter (DIY) 1997 Civic LX
  184. Glue residue
  185. Natural Gas Car
  186. Switched to AMSOIL
  187. is Ethanol at 10% safe on a 6th generation civic?
  188. Pulstar plugs
  189. fuel pressure regulator
  190. Question About fuel efficency
  191. Water-no-gas.com
  192. OIL SPRAYING - from one canadian dude
  193. GAS SAVING Suggestions/Tips!
  194. Advice on 150,000 checkup
  195. need valve train for b16a2
  196. problem with 96 accord. help!
  197. Tuning My 89 Civic
  198. Will 91 CRX tranny fit in 88 Civic?
  199. missfire plus crankcase pressure!need help
  200. E-manage
  201. allmotor h22 help?
  202. air filter replacement
  203. First Oil change and when to switch to M-1?
  204. Gurgling Sounds from the Passenger Side??
  205. 100,000 Mile Service
  206. What fuel filters to use??
  207. DIY oil change is more expensive?
  208. Recommended octane?
  209. Gates Racing Timing Belt
  210. Best place to buy oil?
  211. Maybe squeaky belts?
  212. Cleaning engine on 04 civic
  213. First oil change - advice
  214. 1998 Civc Jumpy RPMs cant pass smog (I need Help!!)
  215. removing foam sticker from wheels
  216. Best Interior Protectant?
  217. Oil Change
  218. 5w30 ok?
  219. Honda Recommended Lubricant list
  220. Steering oil/fluid
  221. Transmission problem
  222. Several problems, not sure what it could be. Help?
  223. gas mileage way down???
  224. 89 civic fuel filter replacement?
  225. Stalls at half a tank. Any ideas?
  226. Average fuel economy
  227. Too much oil?
  228. Starting problem on 07' Civic. Help!!!
  229. Civic takes a while to start then shuts down
  230. CAM2 High Octane Fuel
  231. To Flush or not to Flush?
  232. maintenance required
  233. DIY Complete ATF Changeout Procedure
  234. Changing coolant, da bolt won't friggin move!
  235. How much Lucas oil?
  236. 83 Civic carburetor problem
  237. Fuel cutoff reset?
  238. stuck spark plug
  239. Is stalling a cause of bad alternator?
  240. Switch Oil?
  241. Raised fuel consumption
  242. PCV valve 1997 EX
  243. Zymol Royale
  244. synthetic or petroleum
  245. Power Steering issues
  246. Oil pan nut but missing washer
  247. Rust proofing
  248. Spark Plugs (NGK Iridium High Performance Spark Plugs)
  249. About to change my ATF and i have 3 Qs
  250. car won't go into gear!
