Trunk latch bounces open
Hey guys,
My 2001 Honda Civic EX trunk latch will not stay latched, I have tried adjusting the striker plate up, down, left and right. I cannot get the latch to lock onto the striker bar. The latch can be pushed into closed position with a screwdriver, but when closing the trunk (normally) the latch wont completely click onto the striker bar. Is the latch no good? I also screwed the rubber bumpers that prevent rumbling all the way in. And lastly I sprayed the hell out of the latch with WD40. Still no luck..
Thanks in advance
Thanks in advance
Re: Trunk latch bounces open
if you tried all those adjustments, you prolly need a new latch. if you have aftermarket alarm, why not go with the 01 accord electric latch that you can wire to the alarm and have a remote trunk opener.
the latch does not have that much adjustment pull it off and shimm it with some washers between the latch and the body. doing this moves the latch higher giving it a better chance to lock on. this is a notorious problem with the carbon fiber trunks
yea im having the same problem also with my 01. I just shove it down real hard in the center and it stays shut but still its a pain. Also my key wont turn to let me in the trunk i gotta use the lever to open it up lol
I think I threw away my stock trunk lock, otherwise you could have it for free. Just pick up an Accord actuator and hook it to your alarm like gearbox said.
my 03 and 02 have the same issue. Honda wants 87 bucks for a new latch. i tried moving the striker around and i checked the cable for release too but it appears the plastic has just worn down so much there's nothing to push the latch over and lock. i may look into the accord latch as mentioned previously
Check your rubber stoppers on the left and right side of the trunk, make sure theyre not sticking out too much if they are twist them to the right and theyll go back in. Probably wont make a difference but just one more thing to try. If the latch is broken go on www.car-part.com and find one at a scrap yard in your area
18
Aug 17, 2015 08:02 AM
h4ldol
19
Jul 28, 2015 01:01 AM
brainwashedmc
Jul 27, 2015 10:05 PM
ayoitzjulesdx98
Jul 26, 2015 02:25 PM
