2001 Civic EX - Wipe Fluids not squirting
Hello Folks,
The windshiper wiper fluids are not coming out from my 2001 Honda Civic EX. Normally, when it is out of fluid, I would at-least hear the pump/motor making a noise. But today..there is absolutely no noise being heard either.
Not sure what could be wrong. I'll take it to the dealership tomorrow morning. However, I would appreciate if somebody can provide me with any probable cause for this malfunction. Is the fuse shorted out or does the pump need to be replaced? Any other reason for this? I know I have had the pipes blocked before but in those instances I would hear the pump going -no such luck this time around.
Thanks for your tips.
Regards,
Shams.
Regards,
Shams.
Re: 2001 Civic EX - Wipe Fluids not squirting
my first thoughts when i read the post title:
did the previous owner give the car a Vasectime?
or mabye it's abstanit
or mabye it's tired of the same old hag (you) and dosent find u sexy anymore
sorry had to do it
sorry had to do it
Prowlin' with a Purpose
if the wipers work and the pump isnt.. its not a fuse.. they run on the same fuse.. probablly check to see if the washer pump is plugged in.. yes i know, but ive seen some body shops forget to plug that in.. secondly, what type of weather are you in? might have frozen washer fluid.. i see that a lot this time of the year too
*edit*
also if your nozzles are cracked you wouldnt be getting a good spray, but if there isnt any noise, then something is wrong with the pump and/or wiring to the pump
*edit*
its the washer pump if you dont hear anything. alot of times the plug will just get really dirty and finally some will go in the plug and ruin the contacts. take off the bumper and have a look, its stuck right to the side of the fluid reservoir.
ive just had an interesting experience, car comes in, no noise heard from the washer pump, but everything else works... pull the pump out of the reservoir, ICE... all up in there rendering the pump inoperable, quick fix, hit it with hot water... run hot water through the reservoir with the pump out to flush the ice out
lol i guess someone didnt feel like paying the extra dollar for washer fluid with a low freezing point.
I'm pretty sure it's your pump... Try all the ^^^ first.
I'm currently looking for some nozzles, but am not having any luck. I just want the regular black ones. Not those ugly chrome led ones.
mattdoc
Mar 14, 2017 12:10 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
