Spark Plugs (NGK Iridium High Performance Spark Plugs)
Old Aug 19, 2007
carter's Avatar
carter is an unknown quantity at this point
I Bought 4 NGK Irdium IX spark plugs I am wondering how much better these would be then the ones you would find for cheap at say a canadian tire?
Was it a good buy? Along with proper Air Intake and Air Filter and other few things would you notice a bit of a difference in the cars performance after 97000K ?
Old Aug 19, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
Re: Spark Plugs (NGK Iridium High Performance Spark Plugs)
its a great investment, be ready to have your car feel like its running alot smoother. Thats the only way to describe it, smooth..
then again u might also get a increase in MPG as well. u never know
Denso/NGK FTW
Old Aug 19, 2007
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
are they really THAT much better than plats?
Old Aug 19, 2007
LT2004ever's Avatar
who said anything about platinum?
Old Aug 19, 2007
the stockers are double plats. i personally didnt notice any difference going from copper plugs to iridiums. but whatever, i paid alot so im keeping em lol
Old Aug 19, 2007
ryox82's Avatar
I hear yeah, and thats why I asked, because when I pulled mine out to put in copper plugs they were plats. Was wondering if there would be a difference. I noticed a difference putting the copper in but then again it could have been from just being new plugs.
Old Aug 19, 2007
LT2004ever's Avatar
oh!! ok i gotcha, i thought we had copper stock.... lol i see ranking like copper, plat, iridium. Kinda like bronze, silver, gold. Sorry for the noobish confusion on my part
Old Aug 19, 2007
ryox82's Avatar
Its cool bro, im not always exactly that clear either when I am trying to say/explain something. From what I have gathered from other discussions was that coppers ignited better, but plats and iridiums lasted A LOT longer. You didn't notice much of a difference going from coppers to iridiums gearbox? Its a huge price difference thats why I am concerned. Hell if it is worth it, I would jump on it.
Old Aug 19, 2007
platinum is only for having a longer service interval. it conducts worse than copper. iridium too, but the smaller electrode makes up for it i guess and requires less voltage from the charging system.
Old Aug 19, 2007
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
ive heard on honda-tech that iridiums are usually best for when you run boost, otherwise it doesnt matter if you run copper or plats, FTR-4pt platinum runs like sh*t (bosch).
Old Aug 19, 2007
greeen01civic4d's Avatar
have ngk iridiums on both of mine, both run great, does improve gas mileage slightly
Old Aug 19, 2007
hmm i heard copper is best for boost and iridium is not good.
Old Aug 20, 2007
Dticalman81's Avatar
Dticalman81 is an unknown quantity at this point
Just use the OEM Double Laser plats. I installed them recently having using denso iridiums and ngk iridiums up til 99k, but the OEMs work the best.
Old Aug 20, 2007
ive tried both, im using denso, the only dif is denso uses a smaller electrode so technically it is better. my ngks didnt last very long tho, like maybe 15k miles before they looked beat.
Old Sep 18, 2007
HiPWR Racing's Avatar
HiPWR Racing will become famous soon enoughHiPWR Racing will become famous soon enough
my plats are pretty good i think. they run really well with the hotter spark from a blaster coil.
Old Sep 14, 2010
enricolaguardia's Avatar
enricolaguardia is an unknown quantity at this point
where can buy this laser iridium ngk plugs?
Old Sep 14, 2010
laser iridium is not available for 01-05 civics.
Old Sep 15, 2010
sl33pyriceboi's Avatar
anyone try those E3 yet? im just curious? any comments steve?
Old Sep 15, 2010
garbage. i would give em 1 month before they fry. not even recommended for lawn mowers.
Old Sep 16, 2010
Kennykid2002's Avatar
Kenny the Ricer
Anyone know if the NGK V-Power's are any good for DD?
Are they the copper ones?
Old Sep 17, 2010
they are copper, and they are great for a cheap plug. same performance as the denso iridium, but uses a bit more electrical system power to make the spark. copper conducts best, just replace em every year (or two) for max performance.
Old Sep 17, 2010
Kenny the Ricer
Didn't wanna cheap out, bought the iridium IX's
10 minute job
The only word for it is SMOOTH
wow, everything feels so much more better
I guess stock's looked like denso plat's
normal wear and tear on the old denso's,
but these iridiums i can feel the difference already, love em!
Old Sep 20, 2010
mac25's Avatar
Dr Krieger of Modification
i don't really know how spark plugs work internally. but if the conductivity in the metal is the only reason people buy more expensive plugs i highly doubt they're worth it. think of how fast the electricity is moving. do you really think it matters if the resistance in the metal is that of copper or platinum? so what if platinum reacts "slowly (in electical terms that is)", because the gas is still going to combust at speeds far less then an electrical spark. wouldn't the only reason a metal with higher conductivity would be better is if you needed more amperage (the amount of energy delivered). i mean really the only reason you'd want higher conductividy is to decrease the power draw from your battery. you know ohms law, lower resistance lower amperage needed to generate the desired voltage.
Old Sep 20, 2010
iridiums also have a finer electrode, so less energy needed to make the same spark. platinum plugs also tend to run hotter than most copper and iridium and should only be used on a stock motor. if you have turbo, i would only recommend copper and change them very often, prolly every oil change at 3k.
Old Sep 21, 2010
mac25's Avatar
cool, well then i'll stick with platinum unless i go tuned =D
Old Sep 26, 2010
kofrad's Avatar
kofrad is an unknown quantity at this point
Question Re: Spark Plugs (NGK Iridium High Performance Spark Plugs)
All this talk on different materials for the spark plug is getting me confused.
I'm going to change the spark plugs later on this week, I'm thinking about getting the NGK GP Platinums. Is this a good call for a stock '03 Civic DX? Or should I stick with copper? Is there any noticeable difference between the plugs with an extra gap on them?
Old Sep 26, 2010
Kenny the Ricer
Your choice
Copper - Better conductor
Platinum - Longer lifespan
Iridium - Combination of the 2
I say spend 30 bucks on Iridium, and d/w about it for the next 100k miles
That's what i did
Vid on how to change em
https://www.civicforums.com/forums/7...nge-video.html
Old Sep 26, 2010
kofrad's Avatar
Thumbs up Re: Spark Plugs (NGK Iridium High Performance Spark Plugs)
Your choice
That's what i did
Initially I had planned on the iridium, but was under the impression they wouldn't give me anything more than the platinums. For the extra $10, I'll just get the iridiums then.
Old Sep 26, 2010
well idk about all iridiums, but denso is only rated 30k miles. thats hardly long life but still worth it to have the better performance.
danace99
23
Jun 28, 2015 08:49 AM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
3rdcivic
Oct 21, 2001 01:26 PM
