Oil pan nut but missing washer
Rep Power: 0 Oil pan nut but missing washer
Recently bought a used 4D 2006 Civic EX. The previous owner did his own oil changes and I noticed after emptying the oil from the oil pan that there was no washer with the nut. I had to finish the job and so was forced to put the nut back without a washer and fill up with new oil.
How important is this washer? Will I get by until the next oil change or does this washer serve some crucial function whch I presently don't understand.
Jap-Euro Fusion
Rep Power: 399 Re: Oil pan nut but missing washer
The crush washer is a safety seal. When oil gets hot, it gets thinner, it can seep out the threads. The 1 time use washer crushes between the bolt head and pan, creating a seal.
Rep Power: 0 Re: Oil pan nut but missing washer
http://www.handa-accessories.com/civmaint01.html
^^^ there selling a 6 pack of those. I bought them. & I change it after every oil change
Rep Power: 224 Re: Oil pan nut but missing washer
i just started changing mine after every change, you can get the washers at napa too. honestly you can get away with using the same one a few times. ****, i never changed it on my first 7th gen, and never had a problem.
Rep Power: 787 Re: Oil pan nut but missing washer
i got a bunch free from my old dealer parts dept. but if you buy it theyre like 10 cents each
Slowest 7thgen in the GTA
1 Post
Rep Power: 262 Re: Oil pan nut but missing washer
You can use the same washer several times. I prefer to change it every time though. The washer cost almost nothing to purchase, so you might as well change it every time. Better to be safe, than sorry.
7th gen old timer.
Rep Power: 319 Re: Oil pan nut but missing washer
hmmmm lol i never replaced mine.... i just did the oil pan on my b18 and i go outside to a puddle of oil oil seal is fine its coming from the drain and it has a washer but its prob bad.... ill have to try this befor i get a new oil pan...
Vaguexo
06-13-2015 04:11 AM
jmdcivic
05-20-2015 09:52 PM
