scratch-X and orbital?
I have a porter cable 7424 random orbital and foam pads - can I use with scratch-X to get out a few razor blade marks I got when taking off a pinstripe?
Tips appreciated...
Tips appreciated...
Re: scratch-X and orbital?
you could, but i would do it by hand. while scratch-x does have diminishing abrasives, it still slowly polishes away the clear coat and too much will burn it right off.
I find scratch x to be very mild. I would get some rubbing compound, work it in by hand or machine(whichever it states AT THE CORRECT SPEED), follow it up with a finer polish to remove the scratches it puts in, then wax it!!!!
rubbing compound is very harsh, like using a sandpaper. i used a few applications of this but only because i had to strip the entire UV coating off a pair of headlight lenses (coating was peeling and hazy). they looked trashed after i was done and i still have some scratches that almost a whole bottle of plast-x would not remove. but they still look better than before. just be careful with rubbing compound if theres no other choice.
rckdrmr
Oct 19, 2004 12:56 AM
