Power Steering issues
Old Aug 28, 2007
luvnlife64's Avatar
luvnlife64 is an unknown quantity at this point
My power steering sounds like its about to go. Without turning the wheel, it will make the sound/noise as if its pumping the fluid. No leaks that I can see. Is this a sign that the power steering pump is about spent?? My Honda has 122K miles.
Old Aug 28, 2007
Re: Power Steering issues
if it making a loud whine type sound when you turn the wheel, then yea its on its way out.
Old Aug 28, 2007
luvnlife64's Avatar
no - no major sounds when i turn the wheel - understand that much - it's almost like a computer glitch - like its getting a signal to "use" power steering
or something
Old Aug 29, 2007
speedfoos's Avatar
Change out the fluid. See if its still making noise after that. $3 diagnostic. Even PS fluid needs to be changed every once in a while.
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
RIPSAW
Nov 6, 2015 04:36 AM
moorebl
Aug 29, 2015 08:39 PM
EdGasket
May 25, 2015 01:06 PM
anddrrey
May 11, 2015 02:30 PM
